Rebuilt motor, first startup I've got a strang noise help please
Then most likely the cambelt is too tight. Sometimes the bearing fails on front of powersteering pump and sounds like it's coming from the cambelt cover.
Also did you replace the cambelt tensioner stud? The tensioner stud is known to fail due to age.RESPONSE MONSTER
Are you positive you torqued all the cam caps to spec when reassembling the head? on the bright side it doesn't sound catastrophic, but certainly something you want to deal with asap. My guess is something was bolted down to tightly on head reassembly, though it has that distinct kinda distressed rubber sound to it.
Timing belt...and it sounds like its getting chewed up, dont run it anymore untill you get the timing covers off to see what is askew.
Then it might be the tensioner bearing or idler bearing. Higher pressure on old bearings by a stronger cambelt (not a factory cambelt) could cause that type of bearing sound.
You can get a similar sound from CAS bearings x2 if tighten the CAS down incorrectly / unevenly. Putting a mechanics stethoscope on CAS (to see if it is the bearings inside CAS) and just behind CAS can eliminate sound from CAS as a cause.RESPONSE MONSTER
thanks for the responses so far, I've got something to aim at now
