White 'rine project
  • Looks badass man, I like the purple color scheme going on!
    92 Gtst/Silver bullet
    • Haven't had much time to put the rad back on yet. I should have a vid of the exhaust tone soon.
      I'm gonna need a tune in the spring to optimize these puppies.
      264duration 9.0mm lift
      • rad installed now, and is ready to run (when I find a working battery)
        Also the primed/sanded bumper was test-fit. Can't wait to have it painted white!
        • Looking good man!
          • whats your catch can set up look like? and how did you remove the oem neck things from the valve cover to use an fittings? i couldnt get mine off
            - Adam
            • Originally posted by M13 View Post
              Looks so MEAN in that pic!! I'm digging the HKS purple, and matte black rocker cover too
              • Originally posted by amnash View Post
                I have a catch can that will be installed once everything is done. Right now it'd be in the way too much.
                The stock PCV neck comes out if you carefully twist it out using a screw driver. Put the screw driver through the holes then use the leverage to turn it as you gently pull up. It should pop out.
                As for the AN-10 fitting, there was a guy that sold custom fitting bungs for a great price. I dunno if he's on here anymore.
                Honestly, AN- fitting for PCV is more for the look rather than function. You'll save fuckloads of money by using stock fittings and regular hose and clamp. I have a certain look I'm going for under the bay and the AN-10 would complement everything nicely.
                • ya it looks 100% better
                  - Adam
                  • man, I am glad you weighed your cam gears. I've been wondering for the past little bit but haven't had a chance to weigh the stockers to compare with a set of aftermarket ones I had. I just weighed the aftermarket ones I have and they are heavier than the oem units! Arg 584 grams for the ones I got. Im going to get rid of them now. Anyone selling and adj cam gears???
                    ALLEN PETERSEN
                    Number (604) 961-2449
                    RB30`s for sale!
                    • Honestly, the weight for cam gears will be hardly noticed, but I just thought it'd be good information for the community.
                      • Hooked up the battery and the car runs like a champ. mmm cams sound pretty good and rev's so much faster. 264 duration ftw!
                        One little problem though, the stock coolant temp gauge is not working, everything is connected... any ideas? I swear one of these days I'm just going to rewire everything bc I hate having old wires in my engine bay.
                        • Happemd to me too,
                          Ended up being the sensor blewed up.
                          Sent from my HTC Magic using Tapatalk
                          • I just got a new sensor put in. How does it blow up on its own when I haven't touched it since October LOL.
                            stupid oem sensors. Can't wait til I get a STACK in this bitch.
                            • Where'd you get your nistune board?I can't find em.
                              And have no desire to go haltech right now.
                              • How's it running with the new cams? Still relatively drivable?
