Hey man its nice to see that you want to save this from the scrap yard, I'm currently working on my almost writen of r32 gtst, with an rb25det swapped. The way i went was I called around the JDM shops around canada and found a front cut that they took the engine out of, so you get from the dash forward, (-the engin and transmition) and that should have everything you need for frame and rad support. Also the First rule for a smashed car is you want to get the frame pulled, to get the kinks out of the rest of the body.
Also make sure your wind shield isn't cracked or anything, because the cheapest I could get one was $1,000 shipped to my door.
Best of luck to you :P and post some more pictures, I'm interested
Edit: After looking at the pictures again, you will definitely need to get your frame pulled before you cut anything off.
