Project: Ultimate Response GTS-T
  • Project: Ultimate Response GTS-T
    Well over the course of the winter I will try to see if my project is feasable. I will gather as much info as I can as I don't think it has been done before in Canada.
    I currently have an HKS GT2535 and Although I like it very much (very very much :P ) I beleive the RB20 powerplant could be a bit faster to spool.
    Also I'm basically limited to under 400HP at the crank with this turbo.
    I could go for a bigger one BUT. One thing I wouldn't want is added lag!!
    I'm really starting to like my Idea:
    Going for a Twin turbo setup on my 2.2L platform !
    I'm looking for either twin GT2510's OR twin HKS GT-SS's.
    my current Hurdles are: the twin turbo Exhaust manifold for the RB20 head And the Electronics associated.
    I could certainly attach a dummy intake with a single Z32 MAF (My current) but I feel this is probably not as accurate as a twin MAF setup or all out MAP.
    I'm also somewhat worried about the RB20 head that doesn't flow enough air and that it might cause a bottle neck above 400hp
    My funds are limited and I will porbably need to buy a new clutch next year as well as another Diff.
    I will have more details as the project comes along
    here's a teezer:
    Marc-André
    _________
    2.2L RB20 GTS-T
    sounds like a good project.... i hope you will be redoing the bottom end and head?... and with forges internals? what manifold are you going to be using... i would get one from JUN made for the RB20 but looks like the GTR one...
    anyways hope it works out... looks like a good project
    Cory
      Cory
      unbeknown'st to you obviously, klys' engine is already built (rb22), so he already has a good start on most other people
      klys, as for more HP, more HP means more lag
        hey Klys, i was looking around at this myself, from what i've seen on a standard rb20 with stock gtr turbo's 9psi came on at 5000rpm...nto much of a powerband...that could also be because of the piping they used.
        if you need somone to fab the manifold, let me know, i've had it figured out for a long long time how to do it...and on the cheap.
          For sure Mat I will need so help with the manifold!
          I don't get how two small ceramic turbos like that took so much time to spool
          However I'm sure that 9 PSI from both the GTR turbo probably flow more air then my 15PSI. the difference being that my 15 PSI come on at 3500rpm :P
          I'm still thinking .. 2530 for 2.6L 2510 for 2.2L good compromise
          anyways I really don't know yet if this is ever going to happen but I'd love to see it in action
          Marc-André
          _________
          2.2L RB20 GTS-T
            Here are a few Goodies I have received!
            New HKS filters, they say they need to be changed every 5000km?!
            I had been runing my old one for the last 30k
            APP Stainless Steel Brake lines
            I'll see how they hold at the track!
            Nismo SS clutch line
            Well since I have an ORC 709D clutch coming in
            this might come in handy
            A Nismo harned clutch fork pivot
            Last but not least
            An OMP WRC leather steering wheel
            I also bought some Motul DOT 5.1 brake fluid
            to replace my less that a year old DOT4
            Marc-André
            _________
            2.2L RB20 GTS-T
              Well my APP Steel Braided Lines are in!
              It kinda makes a difference but I'll See tomorrow on the track!
              I tried it a couple of times and I got to the braking threshold two three times easily.
              The feel is just a bit stiffer but not overly so
              Marc-André
              _________
              2.2L RB20 GTS-T
                braking shouldn't feel any different during normal driving, but you won't experience brake fade during hard driving with those lines
                  I had a great weekend at the TRAC Racing Academy
                  I must also say that I didn't experience brake fade. Everyone of my friends had some but my pedal was very consistent! and I could repeat threshold braking as I pleased after a bit of practice!
                  great stuff!
                  on the down side my already finished tires are now down to the nylon lining
                  BUT
                  I got me some of these!
                  BF KDW2'S
                  can wait to try them on the track
                  next up I will try to get me some R compound tires
                  Marc-André
                  _________
                  2.2L RB20 GTS-T
                    Well it seems that the car still has surprises up it's sleeve!
                    look at what I found today under the cover
                    Woohooo!
                    I decided to check on the timing belt because it made a weird sound ..
                    can anyone tell me if this is a normal sound? or if the belt seems a bit loose??
                    it stops doing the sound when the timing belt changes it harmonic oscillation or something
                    thanks
                    Sound of timing belt with cam gears?!The Timing belt and tensionner/idler have been changed since thenThis video shows the sound coming from a somewhat loose...
                    Marc-André
                    _________
                    2.2L RB20 GTS-T
                      Nice project and ideas you got going for your Skyline!
                      I would recommend you change your timing belt for a Nismo or Tomei one.
                      $150.00 is not much for a piece of mind! Plus you would want to change it anyways before you make the power you want to make with this project!
                      Is it normal for a timing belt to flap like that when reving the engine?
                      Your car sounds awesome BTW!
                      My cars:
                      1996 BCNR33 GT-R
                      1992 FD3S RX-7 Type-S
                        ya for sure
                        belt and tensioner are on the way already!
                        Marc-André
                        _________
                        2.2L RB20 GTS-T
                          Also Got me a brand new ORC 709 twin plate clutch!
                          pics to come
                          it's a beaut to bad it's all hidden up in the tranny
                          Marc-André
                          _________
                          2.2L RB20 GTS-T
                            Saw your car at Redline Time Attack...she looks great !
                              thanks
                              I did finish 3rd which is Good but not as good has I would have like..
                              the red BMW M3 was also on street tires ... I would have like to be has fast as him
                              Marc-André
                              _________
                              2.2L RB20 GTS-T
