Will 10w30 be too thin??
Engine fluid quantities?
This is a sticky topic.
ok going to correct some stuff here as I just replaced all my fluids...
Tranny GL-4 Motul Motyl Gear Technosynthčse 75W90 3.8L
Front Diff Motul Motyl GL-5 Gear Technosynthčse 75W90 fill to hole (1-1.5L)
Rear Diff Motul 90 PA fill to hole (1-1.5L)
Transfer Case Motul Dexron III 2.8L
Motor Oil Motul 8100 5w40 (in the owners manual 5w-30 is the suggested oil but since its slightly modified the slightly heavier oil is used)
8100 is good for everyday driving however if you want to free up a couple extra horsepower use 300V as the friction loss reduction is greatly reduced I've witnessed independent tests first hand were 300V has freed up 5-7% more HP than mobil one and castrol "synthetic"... the 300V that you buy is the same exact oil used in the JGTC cars, they get the same can as you do :P, its just a little pricey but if you use it you can definitely tell the difference...
as for the reason why there is an additive in the Rear Diff, its because the front is an open diff where as the rear is not I believe...
The Tranny is not 4.1L, as i did this and it over flowed my tranny once i started driving (and you will have tranny oil spewing everywhere when you do your test drive :P)... from what we can see i think this is meant to be 4.1 quarts which is about 3.8L's :P
LOL this was a huge scare as i though i had some major leak in the tranny :P
anyways thats all past now and the car is running awesome hope this info helps peopleTeam TBA sponsored by YOKOHAMA: YOKOHAMA, Feast AE/RS, Titoboy Approved, Importfest, NextMOD, DSPEED.
http://www.facebook.com/TitoboyApproved "like" us #doWhatULove
I know I am digging up old thread but as long as it is useful.
Anyway, I have a GTS-4. So should I be using the quantity of what Neal has mentioned? ~~ I think I do have transfer case and front diff right???ops:
MavIn the end the gov't will do as they please and if they do kill the 15 yr rule life will go on, and we will find other cars readily available to pour our hearts and wallets into. The Skyline is a great car, but its not the only one. It might be a case of easy come easy go.------------- JZ
