Hey,
I've been doing some searching but with few results. I've started tearing down my car for the winter build and I came upon a few things that I am unsure about. The previous owner kinda slapped the car together and now I get to fix all the issues (horray). My questions are as follows:
1) What is the bolt size for the coilpack cover of an rb20?
2) Does anyone know the part number or even the name of the crank angle sensor arm? I removed the cam gear cover only to discover that the solid arm which bolts to the engine is cracked. I'm sure I can run the car without it (have been so far) but I'd like to get a replacement if I can.
3) What does everyone use for painting the rocker cover, cam gear cover and coilpack cover? I'm looking for a nice deep red and I've been into Canadian tire but I don't always trust what they suggest.
4) I would love to eventually change the head gasket for a metal one and put in some ARP headstuds while I'm at it. Is it best to remove the engine from the car? Or can I get at it without too much blood? haha
5) Does anyone know the part numbers for the tensioner, tensioner spring, etc for changing the timing belt? I'm going to do all the belts and I might as well do the works while I'm in there.
6) I have a Greedy BOV installed on the car but I never realized how many vac hoses run through the car. Do you still have the stock BOV (on the J-pipe) running if you have an aftermarket one? If not, do you just remove and/or block the lines or what's the general procedure for that?
I really appreciate all the help from everyone. I'm sure some of these have been answered before but I gotta ask. Sorry for all the questions, might as well put them all in one spot. Oh and for the record, the car is a 91 HCR32.
Cheers
Cheers
