So at the track on Friday, on my last run my steering went heavy and the HICAS light came on and has been on ever since. My power steering fluid level is fine and so is the fuse. What else could it be? Only thing I could think of would be power steering pump, but how would I test that? Also, could it be anything else? r32 gts-t btw
Power Steering Problem
Fluid level sensor could be stuck, try tapping on the side of the reservoir and see if that helps. Normally if a pump is going or has gone you'll know by the whining sound it'll make, it's very noticeable.1989 R32 Skyline GTR SOLD!!!!
-Bruce Lee
When I bought the car both wires were broken off with no hicas light on and full steering. A couple months later, the light came on after the first time I turned the wheel while driving, and then days later went heavy due to a blown fuse. Replaced that and still had the problem where everything is normal as I start but after turning the wheels the light comes on. No problems though. Then the other day steering went heavy, no fuse is blown and as far as I can see, nothing has changed
I've heard the same thing too. Apparently there is a sensor in the steering hub that lets the hicas know when the steering wheel is centered, if it doesn't get the signal the light comes on. Once the light comes on, hicas is disabled which can cause the car to "crab walk" down the road cause it will lock up in whatever position it is in.Originally posted by m_melen View PostHah, facking T9 autospell. My light is on, I was told it could be because of my aftermarket steering wheel1989 R32 Skyline GTR SOLD!!!!
-Bruce Lee
