Clutch change, what else?
  • Clutch change, what else?
    Changing my clutch this winter. I'm gonna replace the trans fluid also, but what else should I replace/check while I'm in there?
    Thanks.
    Clutch pivot ball while your in there can't hurt.
    Rear main seal could be worth doing as well.
    The Evil 4 Door
    Nissan Skyline GTS-4 Sedan
      Same p/n apply to rb25?
        The rear main seal is the same for all RB's and the pivot ball is the same for push type clutch setups.
        The Evil 4 Door
          I would recommend Nismo pivot ball as they are stronger than oem and a must if your going stage 2/3 clutch. Also a good upgrade is the Nismo braided clutch hose which also eliminates the hydraulic damper on the lines. I did both on mine Terry and with a spec2+ it launches pretty good.
          Sent from my SGH-I337M using Tapatalk
            Could you send me the p/n's for the pivot and line? Have to track down a supplier for it all. I think I have the correct p/n for the rear main seal. I was looking at the maze of clutch lines, seems like a bunch of useless places for fluid to hang out lol. I have a up-rated clutch for a 300zx it's supposed to be about 10% over stock so it's basically the same, no need for heavy clutch yet, still saving up for power up!
              Tranny is out. I had a noise which I assumed was the throw out bearing. New one came with the clutch I bought. The old one was a bit dry, and made a noise when spun BUT....... When I checked the input shaft, seems to be more than normal play😞
              He's a quick vidhttps://vimeo.com/152095148
              What do you think?
