What happened to TSS?
  • #91
    1x R32 brake booster
    1x R32 windshield washer motor
    1x R32 GTR attessa pump assy
    3x 240sx 6bolt axle
    1x R32 GTS-t 5bolt axle
    N5
    1x box misc Z32 water lines vg30dett
    1x R32 GTR intercooler (has hole in core)
    1x R32 hybrid FMIC
    1x R32 GTR bumper mesh
    1x R32 GTR lsd and axle cups
    4x R32 sunroof parts
    2x R32 sunroof interior panel
    1x R32 skid plate
    L2
    1x misc box of gloria engine parts
    1x misc box of sensors
    1x misc box of wiper arms
    L3
    1x 10” sub box
    4x R32 front strut bar
    2x R32 rear strut bar
    1x sr20det cams
    4x volk racing center caps
    L4
    1x misc box of interior brackets
    1x misc box of seat belts
    L5
    1x R32 trunk tool kit
    1x misc box of Y32 gloria springs
    2x cd changer
    1x R32 steering column
    2x R32 brake booster
    2x R32 auto shifter
    1x R32 brake pedal 5spd
    M1
    1x R32 hood liner
    1x R32 underdash bar
    3x R32 GTS-t hood latch brackets
    2x R32 GTS-t hood latch
    2x R32 hood latch cable
    2x Aristo hood shocks
    2x R32 rb20det ign coil cover
    2x R32 rb20det upper tbelt cover
    1x R32 hood prop
    2x R32 rb cam angle sensor
    M2
    13x R32 rb misc cam shafts
    2x misc boost solenoid
    1x R32 GTR rear tbelt plate
    2x R32 GTS-t rear tbelt plate
    3x R32 hicas control solenoid
    2x R32 rb cam gear
    4x R32 aac valve
    1x R32 oil pump rb20det
    4x R32 wiper motor
    4x R32 throttle sensor rb20det
    M3
    6x R32 fuel pump various
    1x R32 fuel rail rb20det
    1x rb25det power steering pump
    8x R32 GTS-t fuel pump bracket
    2x R32 GTR fuel pump bracket
    1x misc fuel pump parts
    1x R32 air regulator
    1x misc box gauges, lines, shift knob
    1x Q45 throttle body motor
    4x R32 wiper linkage parts
    1x R32 GTS-t p/s pump
    3x R32 evap canister
    L2
    1x misc box interior plastic
    1x sr20det injector set
    1x misc box door hinges
    3x box of rb20det injectors
    1x box of trunk release latches
    L1
    6x misc steering wheel hub cover
    3x R32 shifter floor seal
    3x R32 horn button
    3x R32 horn
    1x R32 steering wheel hub
    1x R32 rb20det p/s adjustment bracket
    1x R32 auto shifter assy
    5x R32 shifter
    1x Aristo s. column switch assy
    1x R32 s. wheel position sensor
    1x R32 center vent
    1x S13 blinker/headlight switch
    1x R32 steering column surround
    1x R32 clutch master cyl
    1x R32 clutch hydraulic line
    1x R32 GTR down pipe
    1x R32 coil harness
    1x Aristo cd changer
    1x Z32 steering wheel
    K5
    1x box of misc wiring
    1x R32 speedo cable
    K3
    2x misc box R32 seat belts
    1x misc box R32 modules
    1x misc box gauge cluster parts
    14x r32 gauge cluster
    K2
    2x pioneer stereo crossover
    12x misc stereo decks
    1x misc box R32 HVAC parts
    1x misc box R32 window switches
    K1
    1x misc box R32 seat belt covers
    1x misc box R32 interior lighting
    1x misc box R32 switches and relays
    1x misc box R32 door handle parts
    1x misc box R32 shifter parts
    6x misc front door windows
    1x R32 floor mat set
    2x R32 rear floor mat
    1x Aristo window regulator set l+r
    1x R32 window regulator
    1x R32 trunk spoiler
    J6
    1x R33 headlights
    2x misc axle
    1x misc cable and window trim
    5x R32 speedo cables
    J5
    6x R32 window regulator
    3x R32 speaker cover
    1x R32 upper gauge console trim
    J4
    1x R32 center console and shifter console
    8x R32glove box
    J3
    17x R32 rear floor mat pairs
    14x R32 rear center mat
    7x R32 right floor mat
    7x R32 left floor mat
    J1
    Xx misc R32 interior trim / sill plates
    3x misc box 180sx interior parts
    I4
    6x R32 upper gauge surround
    I3
    2x R32 blower motor
    2x R32 heater core assy
    I2
    3x R32 blower motor
    2x R32 a/c compressor
    3x R32 left speaker mount
    Originally posted by Oakville
    • #92
      I1
      7x R32 right speaker mount
      2x R32 a/c dryer
      1x R32 a/c evaporator
      1x R32 a/c condenser
      H4
      1x misc box R32 window seals
      1x misc box R32 ducting
      3x R32 blower motor
      3x R32 heater core assy
      1x R32 dash vent tubing
      4x R32 steering column
      2x R32 center console
      H3
      1x spare tire jack
      6x R32 center console
      5x R32 center console cover
      2x R32 center console trim
      8x R32 lower dash cover
      H2
      1x Aristo center vent
      4x spare jack
      H1
      2x R32 “skyline” clear rear bumper trim
      3x R32 GTR front bumper grill
      1x R32 GTS-t to GTR hood conversion lip
      2x R32 GTR front grill
      1x misc box R32 cowl covers
      1x misc box interior kick panel
      1x R32 trunk carpet
      2x misc R32 trunk interior panels
      G5
      6x R32 GTS-t front spoiler motor
      2x R32 GTS-t front spoiler assy
      G4
      2x R32 right taillight without cover coupe
      2x R32 left taillight without cover coupe
      3x R32 right taillight coupe
      3x R32 left taillight coupe
      1x R33 taillight set
      1x misc box light parts
      G3
      1x Y32 Gloria left headlight assy
      1x R32 non projector headlight right
      1x R32 projector headlight left
      G2
      7x R32 projector assy
      7x R32 projector headlight right
      G1
      2x R32 GTR front signal light left
      2x R32 GTR front signal light right
      2x R32 GTS-t front clear signal light left
      4x R32 GTS-t forrnt clear signal light right
      1x 94 accord signal light set
      1x R32 projector headlight right
      4x Aristo door speaker assy
      4x R32 GTS-t lower fender guard
      F1
      1x R32 non projector headlight set
      1x R32 gauge cluster trim
      1x misc box Aristo parts
      2x HID bulb and wiring set
      F4
      8x R32 gas pedal
      1x R32 clutch pedal and bracket
      2x R32 brake pedal and bracket auto
      8x R32 brake pedal and bracket 5spd
      8x R32 ebrake handle/cable assy
      2x Y32 gloria headlight assy
      F3
      1x volk wheel center cap set
      7x misc round headlight lense
      2x rb25 engine mount and bracket
      1x R32 p/s bracket
      2x R32 GTR crank pulley
      1x R32 p/s cooler
      2x R32 license plate bracket
      1x misc wiper motor and bracket
      1x S13 headlight motor set
      3x R32 door spring
      4x R32 gas door
      11x misc R32 door lock mechanism
      2x R32 door handle rear right
      1x R32 door handle rear left
      6x R32 door handle front left
      1x R32 GTR brake duct set
      4x R32 GTS-t hood latch bracket
      F2
      2x Mazda carol headlamp
      2x R32 reverse light
      1x R32 license plate light
      5x R32 left side mirror
      3x R32 right side mirror
      4x R32 side mirror motor assy
      3x R32 side mirror misc bracket/trim
      F1
      2x misc Piaa fog light
      1x Chev Corsica headlight pair
      6x R32 fog light set
      4x misc fog lamp set
      E4
      1x KYB front strut
      2x KYB gearclimb R32 front strut/spring assy
      1x Tein R32 GTS-t rear coilover set
      2x HKS R32 rear coilover hat
      1x Bilstein R32 GTR strut/spring set
      7x R32 GTS-t front strut/spring
      1x Y32 Gloria rear strut set
      1x Y32 Gloria front strut/spring set
      10x misc R32 front strut
      3x Atsugi R32 GTR strut/spring
      1x GAB R32 GTR strut/spring set
      1x Bilstein R32 GTS-t strut/spring set
      14x misc R32/Y32 suspension spring
      E3
      2x R32 front upper control arm
      1x box misc R32 suspension parts
      E2
      1x R32 GTR compressor outlet pipe
      1x R32 GTS-t compressor outlet to fender hardpipe
      1x R32 GTR HKS twin kit charge pipe set
      2x R32 dash water temp sensor
      2x R32 GTR intake air temp sensor
      1x R32 a/c bracket and pulley
      1x R32 GTR throttle body set rb26
      1x R32 GTR intake manifold rb26
      2x R32 GTR intake plenum rb26
      1x R32 GTR lower intake manifold rb26
      1x R32 front upper control arm set
      3x R32 intake ducting
      1x R32 GTS-t crossover charge pipe rb20
      1x R32 GTR turbo outlet pipe set (f+r) rb26
      2x HKS R32 intake
      3x HKS R32 GTR afm adapter
      1x R32 GTR bov recirc “y” pipe
      1x M’s R32 GTR intake kit
      D2
      1X Aristo headlight set
      2x R32 GTR oil pan rb26
      C3
      1x Multi function strobe light kit
      1x 240sx rear marker light set
      1x Mitsubishi EVO headlight set
      1x Y32 Gloria center vent
      1x Y32 Gloria steering wheel sensor
      1x Y32 Gloria wiper switch
      1x Y32 Gloria front left door handle interior trim
      1x Tomei Z32 320km/h speedo
      2x wide rearview mirror
      5x R32 leather ebrake boot
      5x R32 leather shift boot
      1x R32 sedan left outer window trim
      1x R32 sedan right outer window trim
      1x OS Giken R32 triple plate clutch
      2x OS Giken R32 twin plate clutch
      2x R32 GTS-t front tension rod
      1x 5mm wheel spacer
      1x Jeep liberty rear brake shoes used
      1x jeep liberty front brake pads used
      2x 20mm wheel spacer
      2x 4886063 Trustop brake rotor
      1x 4.25” silencer
      1x SR20 starter
      9x R32 misc starter
      5x R32 a/c compressor
      1x misc box rb26 turbo parts
      1x R32 GTR turbo set rb26
      1x Z32 turbo set vg30
      1x R32 GTR top mount twin turbo kit complete
      1x RB25 turbo
      2x RB20 turbo
      1x R32 GTR exhaust manifold rb26
      2x R32 GTS-t dump pipe rb20
      2x R32 GTS-t exhaust manifold rb20
      2x R32 GTR painted engine cover set
      2x R32 GTR painted valve cover set
      6x R32 alternator
      1x SR20 a/c compressor and bracket
      1x misc box R32 turbo parts
      9x misc non machined flywheel
      1x misc box rewrapped R32 steering wheels
      • #93
        wow..that's a crazy list of stuff..but there's still no drive shaft from what i see..i really need a new one
        • #94
          someone should checkout the odometers see if ones gojiras
          • #95
            Wow that is quite the list. Thanks for that. Lots of those parts seem very familiar. Only other question is do you have the date that email was sent out?
            It's better to burn out then to fade away
            • #96
              jan 16
              • #97
                Originally posted by doublejceballos View Post
                jan 16
                Thanks. Very interesting since we won our case in December so legally he could not dispose of any assets with a judgement against him. Oh well what goes around comes around I guess.
                • #98
                  So what is the status of all of these parts...?
                  • #99
                    Yes I agree, I want the stock r32 gtst air box
                    • looks like they are all in a mystery location, unobtainable.
                      I hear unobtainable parts are 20million a kilo on earth
                      Wait...Am i mixing story lines here..
                      • Originally posted by doublejceballos View Post
                        from what ive heard, steve is slinging parts for cheap out of his garage. dont know how to get ahold of him tho.
                        Automotive photos from around the Pacific North West.
                        www. BigBoyMedia.net
                        • Originally posted by Bee-RSkyline View Post
                          My car was in there for 3 years. I had an odometer magically appear in the trunk of my car. Maybe this is yours, I will go check in my storage locker. I had a bunch of stuff "misplaced" as well. BOV and Gauges to name a few. Not to mention i was never informed when my car was vandalized and broken into so I couldn't make an ICBC claim for my missing stereo. Steve has avoided me like the plague.
                          Just wondering if you had a chance to check your storage locker yet to see if that was my "missing" odometer?
                          • there is no way to get a hold of any of the main guys from TSS?
                            • Originally posted by celm View Post
                              The Skyline Shop is dead, they are no more. everyone from the shop has moved on to other things. i dont think any one here has been able to get ahold of Steve either.
                              • Originally posted by canadianjoker View Post
                                well then they commited auto theft!!! my buddy sent his skyline to them 2 years ago to get ALOT of work done,and they dissapeared.
