did some work on the skyline (oil cooler filter relocation, rad hoses and power steering lines) and wanted to start the engine and bleed coolant and let it idle for a while to get oil through the cooler etc. so engine was running for a good 10 mins water was up to temp and was trying to get the rear speakers to work while it ran(another story) and all of a sudden the engine stalls and there's a slight bang... try to start it again and it just wont start.. the video below is me trying to start with WOT and while cranking there is a knocking coming from turbo side.
first i thought the power steering pump was siezed becasue the previous day i started it up and the pump sucked the reservoir dry filling the new line, soon as i noticed i shut down got some fluid topped it up today before starting and was fine for the first 10 mins. removed PS belt and issue remained.
the oil i put in was 5w40 amsoil, i know its a bit thick. but the temp was about 5 degrees was thinking maybe the oil was too thick to reach some parts of engine causing seizing somewhere?? maybe to thick for turbo lines?? .. i hope not. during the first 10 minutes of running the oil didnt was up that much either(the gauge didn't even move yet, gauge starts at 140F)
could installing the oil cooler filter reloc. lines backwards F things up? (im pretty sure they're installed correctly, used greddy's diagram)
