Most thread I found was slightly out-dated so i figured that with times, new stuff could mix things up OR feedback on long-term durability of these pumps.
Correct me if I'm wrong,I'm just going by my research found on internet.
STD or N1 oil pump ( can be found for 300$cnd):
The cheapest option you could go with, N1 has slightly higher pressure for higher rpm range but the std gear have 4mm thicker gear.
I personally ran a N1 pump with a collar on a +500whp and was fine with it for about 15k kms but barely did 20 launch and no tracking.
- Reimax gear ( can be found for about 300cnd on rhdjapan +shipping):
Stronger gear, but doesn't really solve the problem of crank clearance and it's not thicker either.. just a stronger material. nothing else.
maybe more realible, but probably not any better than the std/n1 pump in regard of rpm range.
- High pressure oil pump ( greddy, jun, hks) ( can be found for about 1500$ on rhdjapan):
Stronger gear, thicker gear than std but not much. I'm told these oil pump are all the same with different stamp. higher pressure can be a problem without bigger sump because it could suck up too much oil at certains moment. so not sure its a very good thing..
- Nismo oil pump: (can be had for 900$ +shipping)
I'm told its just a N1 pump with reimax gear.
- Tomei Oil pump ( can be had for about 1100$ +shipping)
I'm told this is the best thing for 2 reason: it has the thicker gears of all pump + it's a 3 piece design ( in between with the spline design) that should help reduce the problem of collar clearance .
2) It has variable oil pressure, so you can reduce the pressure so it doesnt empty your sump like the other pump
- Spline design gear type ( can be had for 625aud from spool import and 850ish from supertec):
In theory, its the best design that eliminate the wobble of collar clearance. However, in practice, i emailed spool import they didnt even replied to my email, you never heard of one ppl who ran their spline gear........ hard to know if they are good
Supertec, they claim a few ppl have bought their spline design, they claim a few rb30 and very very high HP machine run them BUT.. i challenge you to find one build thread where someone say he used one of their gear, I couldn't. #2) when asked about these high HP machine, all I found was a picture of a random skyline.. anyone can do that, how about true testimonial from the owner of these cars ? Can't be found.
Nitto, a company I believe that is greatly rated, said that they were working ona design but due to some kind of flaw in the design, the crank could break the gears and for over a year ( if not 2 now!) they are still developping the gears because they are not 100% satisfied with their design.
When asked supertec or spool import, we got a very vague answer on their ''R&D''. At first, i was very keen on buying these type of gears but the more i think about it.. the more i think I wont do it lol.
Whats your take on these?? What would you go for a normal daily-driven car with no extra capacity sump that plans to hit the track now and then?
