It is kinda a pain actually. I made custom adapters, EVO 8 rotors, custom brake lines. Probably took about 6 hours of work to mount the callipers. I would assume looking at the Sti brakes that they are similar for the fronts.
Its basically a piece of steel 1" X .5" X 6". Drilled and tapped to fit the stock hub.
Rear EVO callipers will NOT fit. I don't even think you could make a bracket to adapt.
I ended up keeping stock rear brakes with the EVO 8 rotor.
