Cobraa mentioned it above - is there a engine spec list with what pars you put into the engine ? I corny find it either. I'm still contemplating buding another Gtr and having a friend ship me a rb30 from oz they are super cheap there.
RB30 Build!
I never got around to doing a full spec list yet, i will soon though.
as for the mounts, they are lower but by half an inch, we also lowered the transmission buy half an inch too to get rid of the crookedness. trans is stock, but starting to whine a lot ( not a big deal i have a tranny with PPG straight cut gears waiting to go in that i bought from the UK)..... and diffs are kaaz 1.5 front and back. transfer case is also stock.
CHECK MY FS THREAD!!!!
please.Last edited by greddytrustGTR; 10-25-2010, 11:46 PM.Check out my RB30 build at
http://forums.gtrcanada.com/gt-r-pro...b30-build.html
ooo PPG is nice. not a bad way to spend $8k+ Who'd you get that from? directly from them? Too bad straight cut ain't really streetable but this car isn't really for the street lolBlack 1991 GTR. Serious garage stand mantle/parts car.
nah a friend in the UK sourced it out for me it was from a time attack car that crashed, i paid 3k for it.
and i might be going dry sump too so my RIPS oil pan might be for sale soon
so this is a long overdue spec list of my motor, some stuff might be missing as i'm sure i'm forgetting some stuff,
Block:
- Acid dipped and Fully Prepped Genuine Nissan RB30 Block
- Bored to suit new custom forged pistons
- Custom Billet Rods
- R.I.P.S Block Brace and 4WD adapter kit
- ACL race series bearings
- Genuine Tomei Oil Pump
- Custom Wide oil pump drive
- Genuine N1 Waterpump
- R.I.P.S Custom high Capacity baffled sump
- R.I.P.S Custom mods to Oil System and Gallery
- All New Genuine Nissan Frost Plugs and Oil Gallery Plugs
- Nitrated, Blueprinted and Balanced RB30 Crankshaft
- ATi 1500hp Front Pulley/Damper
- New Genuine Nissan Lower Cambelt Drive Gear, Washers and Keys
- New Genuine Nissan Idler and Tensioner Bearings
- Race Spec RB30 Timingbelt
Head:
- Fully Ported and Polished RB26 Head
- 5 Angle Valve Job
- Ferrea Super Special Alloy Valves
- Ferrea Custom High Pressure Valve Springs (Good for 11,500rpm apparently)
- Ferrea Custom Titanium Retainers
- Ferrea Custom Valve Guides
- HKS 272 degree Intake Cam
- HKS 272 degree Exhaust Cam
- HKS Adjustable Cam Gears
- ARP RB25 Head Studs
- APEX'i Metal Head Gasket
- All New Genuine Nissan Valve Seals, ETC.
Fuel:
- Walbro 255 in tank pump
- 2 Liter swirl pot
- Aeromotive A1000 Fuel Pump
- Aeromotive Fuel Filter
- Dash 10 Braided lines
- Aeromotive Fuel Pressure Regulator
- Sard Fuel Rail
- Injectors i can't seem to remember, either RC Engineering or Precision Injectors, either way they are 1600cc injectors
- Earl's for misc. fittings
- AEM Water/Meth Kit
Turbo System and Exhaust:
- x2 Garrett GT2863RS Ball Bearing Turbos
- Custom Log Style Manifolds made of Stainless Steel
- x2 Tial 40mm External Wastegates
- X2 Custom Dump pipes for wastegates also made of stainless steel
- Custom "Y" pipe also from stainless steel
- APEX'i Exhaust (Cant remember which one)
- Custom Intake Piping and Charge Piping, and you guessed it all made of stainless steel
- Greddy twin inlet 4 core intercooler
- HKS SSQV Blow off valve
- Ported and "Enlarged" the Runners on the Stock Plenum
- Ported and Polished the ITB's
- Genuine Nissan Gaskets for the ITB's and the Plenum
Engine Management & Ignition:
- AEM EMS
- GM 3 Bar Map Sensor
- AEM Tru-Boost Boost Controller and Boost Gauge
- Okada Projects Direct Plasma Coils
- AEM Water/Meth Controller Directly controlled with the AEM EMS
- AEM Wideband Gauge
and i think that should cover the engine and all that
Chassis:
- Custom 6 Point Roll Cage
Brakes:
- PBR Racing 6 Piston Front Calipers
- Volvo V70R 13 inch Rotors
- Hawk Pads
Suspension:
- Nismo F & R UCAs
- Cusco Sway Bars
- Tein Mono Flex Coilovers
Wheels & Tires:
- Volk TE37s Matte Black 18x10.5 +12 offset
- ADVAN AD08 255/40/18
Interior:
- x2 Bride Low Max Reclinable Carbon Kevlar Seats
- x2 Takata Long 4pt Harness
- Bell Works Flip Up Steering wheel Hub
- Nardi Limited Edition "Orido Style" Steering Wheel
Exterior:
- Satin Black Paint
- Fujimura Rocket Dancer Carbon Front Lip
- 8000k HIDs
and that should pretty much cover my whole car, if i remember some parts i forgot i will update this list.Last edited by greddytrustGTR; 10-27-2010, 10:45 PM.Check out my RB30 build at
thx DJ corrected now, and valves my bad i was talking to someone else about valves and i had it in my head while i was typing it out. all corrected now
List has been updated*
and depending on the weather this week and how lazy i am i'll try to take pics of the carLast edited by greddytrustGTR; 10-27-2010, 10:50 PM.Check out my RB30 build at
The OEM valves are good till nearly 1000 hp or 800whp or so they say therefore anything from Ferrea is badass, filled or not. Either way, this car better be over 700whp for what's in it so nothing is wasted
Oh hai der!
kickin it old school!!
Thanks to Adam@Feast Giggity!!Last edited by greddytrustGTR; 02-27-2011, 06:59 PM.Check out my RB30 build at
Wow dude those are some quality parts.... Good job. Are you going to keep the breather tubes where they are or are you going to relocate them? I have seen them before where people used these on a 26 and got earls fittings tog welded towards the back of the covers.... Anywho, great job on the car I look forward to see this cat finishedMiss driving sooooo bad! Need to get a car on the road ASAP!
No my covers!
That's a sweet parts line up! Hope we're gonna see Canada's first 1000hp car
Need moar pix! aha
