Chapter 10 - The Master Plan, part1
no more teasers, you want to know what i'll be doing to my dearly beloved this summer
here it is
i've been ordering parts even before putting the car into storage
so i got piles of boxes
and, if anything can be learned from my previous build chapters, is that i'm not the kind of guy to spend big bucks on only a few select parts, or only work on of the car's caracteristics
so there's going a ton of upgrades, in and out, front and back, under and on top
heres a list of the new parts
Engine, externals
SS braided rad hoses
Apex'i power intake kit
Splitfire coilpacks
new OEM coilpack harness
Cusco oil catch can
HKS special edition SSQV III bovs (2x)
downpipe heat wrap
Greddy adjustable intake cam gear
OEM timing belt kit (timing belt, tensionner pulley, tensionner spring, idle pulley)
custom grouding kit
..will eventually source a KOYO rad later this summer
R34 black ornament plate
Electronics
HKS EVC-S boost controller
HKS Type-1 turbo timer
AEM UEGO wideband AFR meter
Skylab torque split controller (not shown in pictures, haven't receved it yet)
Brakes
R33 brembo calipers
R33 324mm stock front rotors (will eventually switch to AMS's 2-piece R33 rotors)
Garage Saurus big rear 330mm rotors
Garage Saurus rear caliper conversion brackets
SPL front cooling guides
Hawk HP+ front and rear brake pads
Wheels
Ichiba bolt-on wheel spacers, 2 pairs (15mm and 25mm)
Rays Duralumin ''long'' lug nuts
PoorBoy's wheel scealant (aka brake dust shield)
Suspension / chassis
Nismo rear traction links
KTS adjustable front upper control arms
Cusco adjustable tension rods
Cusco adjustable tension rod pipe
Moonface roll-center adjusters
Nismo steering rack bushings
Whiteline adjustable front and rear swaybars
Cusco tri-point rear strut brace
solid steering bushing
Drivetrain
TurboQuip custom SS braided clutch line
Exterior
PIAA super yellow fog light bulbs
Type-A front canards
possibility of a carbon fiber front diffuser (heh nelson?!)
white LED strips
tow hook
Interior
OMP corsica steering wheel (selling it, since i just picked up a uber rare special edition of the same wheel)
carbon fabric and vynil
Autometer carbon fiber 52mm gauge cup
Sabelt harness
blue LEDs for cluster, din gauges and AC (thx to josh for the idea)
cup holder
used console trim, to be carbonized
cluster dial rings
ebay nismo harness shoulder pads
ebay nismo horn button
Here are my plans
(take into consideration that these pics were taken with a cheap camera 2 days before i stored the car, it had been sitting outside for 3 weeks, without a wash)
i'm going to have this harness/roll bar i designed made
since my car is my summer daily driver, i want to keep seating for 3 people, or you know.. a place to put my school bag
and since i'm an engineering student, i designed it too hold from towards force from a body restraining harness, and the downwards force of a possible roll over
so, the big green bar would be 2'' cromoly tubing, flush to the roof, and flaten at one end to bolt to the seat belt pivot, and maybe with a camera mount at the other end, directly in the middle of the car
this bar would be powder coated to hold against the rubbing of the harness, since the harness would be strapped directly to it
the small green bars would be 1/2'' solid aluminum (or steel, in worst case)
the red parts are adjustable threaded bits
the forward facing bars would be bolted to the rear 'front seat mounting points'
and the rear facing bars would be bolted to the rear 'seatbelts mounting points'
all those small bars would be connected to the big bars by helm joints
the height of the harness mounting bar, would make it so that the angle of the harness would be 15deg (FIA approved)
i'm dropping the MOMO Race wheel in favor of my new uber rare special edition OMP Corsica, which is a deep dish, suede, 330mm wheel
maybe i'll finally be able the heal-toe now
to help the heal-toe maneuvers, i'm going to weld extensions to the metal pedal covers so that theres almost no space between the brake ad gas pedals
cluster;
i'm going to swap all the bulbs for blue LEDs, polish the plastic screen, cover the surround with carbon fiber vynil, and put in metal rings in each dial, each ring will be painted flat black
the plastic steering column cover will be covered with CF vynil as well
the Autometer boost gauge is beeing relocated to the steering column cover, with an Autometer carbon fiber gauge cup
the AEM UEGO AFR meter will be installed where the boost gauge was
i'm also going to cover the used/cracked console trim i just bought in CF vynil, and probly the DIN gauge cover too
the Ash tray is getting replaced by the Skylab torque split controller, where its desgined to go
the light bulbs for the cluster, DIN gauges and A/C will all be replaced with blue LEDs to match the radio and the general white/blue theme of the car
swapping the electronics;
HKS EVC-1 boost controller (which was discontinued in 1994, tells you how long it had been there!) will be swapped for a brand new HKS EVC-S unit
HKS type-0 turbo timer (2008 model) is getting swapped with the new type-1 unit that matches the EVC-S
the harness bar will go right behing the driver side seat,
and the Sabelt harness will be installed
the Fischer cup holder (that i found in an old DIY in one of the GTRC forums) will be fitted to the back of the armrest
and i'm also going to wrap the door cards in CF fabric
i'm having the front bumper repainted, because if full of chips and scratches,
the portion where the license plate goes will be filled in with fiberglass of bondo to make it flush with the rest of the bumper
and large white canards will be added to the bumper
and somehow, the huge dark gap between the lip and the bumper will need to be fixed
still haven't decided where i'm going to install the tow hook (which will be powder coated light metallic ''Endless'' blue)
i'm taking the headlights off, to properly fit the new PIAA super yellow fog light bulds in place, because my old ones kept shorting out
and i will realign the headlights to north american standards, because right now, with my non-projector HIDs, i must pissing alot of people off
and i might completely remove the FMIC diamond grill, or replace it with a honeycomb shaped grill
i'm going to get my wheels painted (for the 2nd time), same color, but with a much thicker coating inside the wheel
i'm also checking on how much it would cost me to have custom center caps made (since none exist for this wheel
i'm going to install my new brembo calipers, that i will previously have had powder coated ''Endless'' blue, a kinda light mettalic blue
i'll probly paint the rotor hats de same color
i'll install de wheel spacers, and probly paint them white to match the rims
the front wheels offset's is +38, so i'll put the 25mm spacers for a final offset of +13
and the rear wheels offset's is +28, so i'll put the 15mm spacers for the same final offset of +13
and swap my old faded Rays nuts for new ''long'' type ones, same color
and the rear brake back plates will need to be modified to fit over these 330mm garage saurus rotors
and the side pods with definitely need to be fixed,
i'm going to have them repainted with the bumper
but i'll going to have to take the skirts off the cut the portion that goes under the pod, so that the pod fits snugly
to look something like this
and this enormous gap will also need fixing
ran out of caracters again, continued in next post
here it is
Engine, externals
Splitfire coilpacks
Cusco oil catch can
downpipe heat wrap
custom grouding kit
Electronics
Brakes
R33 brembo calipers
Wheels
Drivetrain
Exterior
white LED strips
tow hook
Interior
Sabelt harness
cup holder
cluster dial rings
Here are my plans
cluster;
