  • frankiman
    replied
    Chapter 38 - The master plan continues
    week1 - 2011
    as always with this project, i have a vision of what i want the final result to be, and try to always stay on the path to acheive that vision
    even though i had done alot in 2010, the project was still far from beeing completed
    so during the winter i again stocked up on parts and planned what i would be able to do in the summer of 2011 ;
    2011 Goals
    1- a friend would help me to take the turbos out to inspect them, and install brand new Garret adjustable wastegate actuators
    2- I was also going to take the big rubber suction pipe that sits on top of the front turbo to swap it with a KTS metal pipe, and also customize it to allow for a 7/8" vaccum hose (instead of the stock 1/2" hose)
    and finally powder coat it satin black to work with the engine bay color scheme
    3- I would be sending my mirror finish ARC aluminium radiator diversion plate to get powder coated flat black, the polished finish didn't work at all with the rest of the engine bay
    4- I was going to make a custom catch can setup with 7/8" hoses all around, to correct my blow by pressure problem
    5- I would be installing the rear section of a Cusco roll cage, which will be modified to allow for a harness bar
    basically, a horizontal bar, behind the front seats sitting just higher than my shoulder which the racing harness will pivot on
    6- I would also going to change out my old HID ballasts, since they are totally blown, place them another way in the engine bay
    7- the biggest change will probly be the addition of an AB Flug carbon fiber front diffuser paired with a Top Secret carbon fiber rear diffuser
    some more CF parts would also be added
    8- the new tires would be either Kuhmo Ecsta XS, Bridgestone Potenza RE-11, Dunlop Direzze Star Spec or Hankook RS3, in 265-275 / 40 / 17 size approximatly
    9- the car is going back on the dyno to see if the new actuators fixed my boost drop problem, if it doesn't, i might get a whole new cat-back exhaust custom made, i'm pretty sure my current muffler/resonator are FUBAR
    10- something really cool will be done with the rear seats
    11- a custom brake ducting system will finally be installed
    then its track, meet, track, meet, ride, etc...
    i already had most of the parts...
    Week 1 - 2011
    the first thing i wanted to take care of, was the removal of the turbos for maintenance and info
    so i enlisted the help of a good friend, Luigi (what we call him), his name is Vulcain on GTRC
    he is a professionnal heavy machinery mechanic, and has done RB26 turbo swaps 3-4 times already
    he likes my car..
    first thing to do was to lift the car on stands, take the hood off and put in on the roof
    and then, obviously install my protect-o-fender
    while Luigi was removing parts from underneath, i was doing the same from above
    it wasn't too long before most of it was apart
    when we got to the actual turbos, all important tubing were clogged with newspaper of rags
    then the old winter storage oil was drained, along with the prestone
    then the actually removal of the turbos and manifolds started,
    everything went well, but the while strying to remove the coolant line going over the manifolds, the fitting nearest to the back of the engine was jammed
    so we tried the usual ''add lube & force'' but we couldn't really get a good angle on it to apply the necessary force
    so we had to think outside the box, or ''on top of engine''
    in the end we couldn't make it budge as we were stripping the fitting, so we opted to bend the line out of the way, in a manner that it would'nt be damadge but still allow us to work in that area
    after a while the turbos were finally off
    here you can see the bent coolant line at the back
    now it was time to find out what i actually had in there all that time
    first off, the dump pipes
    it was clear they were old stainless steel items, looked OEM-ish quality
    when comparing them to stock units, it was clear these were of a much larger diameter, my assumption was that they were from an R34 GTR
    from the information tagged on the turbos, and the fact they were ball-bearing, again it was assumed they were N1 R34 GTR, at the time i had found an image on the web with all stock and N1 turbos from R32 to R34, these were shown as R34GTRN1
    but the tag also shows them as beeing -7s
    i'm confused
    they are both rated for 500hp, which i'm pretty much testing the boudaries of right now
    after there was no shaft play at all, the turbos looked in order
    here it is
    and
    while both turbos were out, i swapped the wastegate actuators from original units (bronze) to brand new Garret adjustable units (silver), i adjusted them for just a little preload, in order to help my loss of boost at higer rpms
    also, when i measured the outlet flanges on the manifolds, and the inlet flanges on the turbos, i realized that since the turbos weren't stock BNR32 units that the size of the ports were completely different, they didn't match at all
    the outlets of the manifolds were 4mm narrower
    so i decided to port match them,
    using 2 pneumatic rotating sanders, one rough the other smooth, Luigi and I did a pretty good job in just a couple minutes
    here you can see the before and after, a big improvement
    while putting the turbos back on, Luigi had a problem within the bracket that holds the rear turbo from underneath and the one that hold the oil line
    ''hey there''
    so it was my turn to go under, i fitted both brackets with minor difficulty, until i realized that when we took everything apart, 1 bolt snapped inside the turbo, a bolt for the bracket
    it would have been easy to extract that bolt while the turbos were out, but now it was too late and we didn't want to back-track
    so while Luigi was putting the front turbo back in, i tried drilling the bolt to extract it from underneath
    it didn't work out so well, so i guess its going to stay like that till the engine blows up,
    its not a big issue since alot of people run aftermarket turbos with no brackets at all
    the worst thing about the removal/installation of turbos on GTRs, is getting the freaking oil and coolant line on them, with very little room to work, and banjo fittings with copper washers and ARGHHHHH
    almost done
    (that was 3 evening's work right there)
    after Luigi left the 3rd day, I reassembled some of the piping and vaccum lines, while admiring the new actuators
    i took the KTS pipe, but it seemed too complicated to work with often, since i do alot of maintenance on the car, i didn't want to lose time to remove it if needed, and it looked awkward anyways, so i sold it, pretty fast
    after that, I fixed a certain issu with my downpipe,
    it had been catching on speed bumps for a while now, and the thick exhaust wrap was torn and hanging under the car
    so I cut off the biggest torn section and clamped it all down using the ''twin worm clamp'' technic
    that was all for the first few days, i am pretty satisfied with the knowledge i had acquired regarding my turbo setup, and that they were in great shape
    more soon!
  • louis110
    replied
    Everytime I read this thread it makes me sad. Sad that I will never be as awesome as Frankie.
  • bellis_GTR
    replied
    Looking through your thread again I realized we had the same problem with the fender liner haha...I was on the highway about to get off the exit and boom, I hear a snap and instantly the steering wheel pulls left, almost putting me in the ditch on the other side of the road. The liner was hanging to low I guess and eventually got underneath the wheel causing the left wheel to slip and loose traction. Once I got off the road it smelt like lots of burnt rubber and found the liner burnt up and in pieces.
    Also going through all the pages, you have came a long way. I bet it feels awesome to go back and look at all this. I really hope I'll have the same progress done within the years.
    Great stuff Franki, love seeing your ideas and work.
  • bobbo
    replied
    I'll keep you advised as the date approaches. If memory serves the application comes out around the end of May. Cost I think was $575 which included initial instruction and both days. Friday is available too for an extra $125. From what my friends said that went last year it's worth every penny.
    Thanks for the brake pad info. Will likely go with Hawks for their availability.
  • frankiman
    replied
    aw man really?
    where did you find the board???
    Everything regarding my ECU was done by Almasi
    The board comes from him
  • RABBIT
    replied
    Im running a stock ecu with nistune
    aw man really?
  • frankiman
    replied
  • RABBIT
    replied
    WTF. why is there two pics in my last post??
    how did they get there? how do i get rid of them?
  • RABBIT
    replied
    Great few pages theses were.
    I literaly was screaming at my computer when you had tyhour break issues : "ITS THOSE FOKING SHITTY AMS ROTORS!!!!!11"
    Knew it,
    Thanks for the backfire/missfire write up , just what i needed.
    sorry , but i missed what management system are you running. I know its either a rom or chip tune but other then that i dotn remember.
    Originally posted by bobbo View Post
    Significant improvement but still not what I'm looking for... Suggestions? I'm looking for a track pad (I'll swap between st and track) but won't eat my rotors up.
    GO with project mu for the track.
    I did ebc in the front and Hawk Hp in the back for the street . either or are great.
  • cschepp
    replied
    Great, thanks man. It would be great to go to a big brake setup bu at this point I'm not ready to shell out 4000$ for a big brake kit. Brembo calipers might cost me 1000$ and then I can buy new rotors so I'll be 2000$ all in. I'll focus on getting a ride on the road and to where I'm satisfied and then go from there. Definitely going to do some track days this year though. I'll have something going.
  • frankiman
    replied
    bobbo ;
    well the Hawk HP+ pads were great off and on the street,
    but with the weight of my GTR, i was thinking of upgrading to Pmu HC+ pads this year, still streetable pads but that can take much more heat
    i'd love to come to tremblant with you guys, it just depends on price and the exact date since, since i'll probly be in the final exam portion of my summer semester at university
    chris;
    the brembos felt great this year compared to 2 years ago when i had the exact same setup but with stock sumitomo calipers
    because of their size they are a bit easier to modulate, and you don't need 1000lbs of force on the brale pedal to slow down
    i think its a worthwhile upgrade, but if you can go bigger do it, GTRs are heavy
  • cschepp
    replied
    Wow I'm kinda surprised the pads and rotors didnt work out for you but this time around I think I'll give something else a shot. With the brembo calipers did you notice a big difference? Right now I am contemplating doing new calipers and brake setup. If you think it's worth it maybe I'll swap to a brembo set.
  • bobbo
    replied
    HAHA! I did... ONCE. I went back to The EBCs that were on the car when I bought it. Significant improvement but still not what I'm looking for... Suggestions? I'm looking for a track pad (I'll swap between st and track) but won't eat my rotors up.
    Also I think I mentioned to you before. A few friends and I are looking to do Tremblant in August with the Boston BMW club. Any interest? We'd likely have room for you. Friend of a friend has a Chalet.
  • frankiman
    replied
    well i don't know what to say really about them, but they just didn't work out for me, so i sold them a long time ago
    i used the stock rotors for all of the 2011 season with good results, upgrading to DBAs for 2012
    the AMS pads are total weaksauce, i hope you're not using them on the track..
  • bobbo
    replied
    Nice work as always Frankie! I'm suprised you're having problems with the AMS brakes. I've got 2 seasons on mine with no issues other than their pads are pretty weak.
