It's just a little turbo
  • #46
    Aquamist is great but not everyone can afford it. By that I mean, if you have a budget build, why go for some expensive w/m system then. You're car is only as strong as it's weakest part
    About the 2 nozzles, you could always cap them off after drilling until you need them. now about the 2 nozzles, who's to say they're even in the correct position? If it's not perfect according to flow path, you could be dumping more into the back OR from cylinder. It's not a "Eye it up and go" kinda thing.
    • #47
      Totally agree with the Eye it up and go" kinda thing.....if there is specifcs on where to insert another nozzel into the plenum and tested to prove that it is better and safer way I will think about it! But seeing as how there is the possibility of too much meth going to the last 3 cylinders without proper mounting of jets I would rather stay with one...If it isnt EXACTLY equal within all cylinders im not too concered because im not relying on it as much as some people are.
      This debate has brought up a lot of great ideas for a very high horsepower to even a small hp car....meth can be used as safety or for running boost off the f'ing charts...very valuable info for all people thinking about running meth
      • #48
        Finally finished the full install of the meth kit...wire tucked and LED light is in....couple pictures of where I put my LED light to show the meth is working
        The little piece of plastic taken out of a $1 pair of sunglasses installed underneath the cruise control light in the center of the cluster....couldnt get an optimal picture of the LED working cuz the lighting was all wack...will have one when car is off the stands and outside
        • #49
          stopped by boost lee's house the other day and made fun of him for not running 6 meth nozzles, then we got into a minor fist fight where he used a drunken master style on me but i was able to hold my ground.
          his plenum is coming along nicely, looked like he burnt off 700 dremmel bits and 12 kilometers of sandpaper but it should look mint when hes done. i also farted in his small workshop and we both hated it.
          it will be nice to see non flaked off oem paint.
          -adam
          1993 Supra hardtop 6spd
          HKS T51R KAI, custom-modified RPS Header, 46mm WG (open dump), 4" turboback, 950cc injectors, dual nozzle AEM 5gal meth kit, AEM v2 ems,
          G&G Performance ported head, full Ferrea +1mm valvetrain, GSC S2 cams.
          around 630~rwhp on pump gas and meth at 24psi
          • #50
            haha... that must be one of the best posts i've read in a while.
            ps. it's a beautiful build and I've learned much from your e-debate. Keep up the good work
            widebody rb25 r32
            friends of:
            genetic tuning!!!
            Originally posted by Muss
            • #51
              Dont confuse me with jackie chan.....I am the master of all Kung Fu....
              As for the sand paper and dremmel bits....yeah a lot has bin used polishing this plenum....one hell of a job I tell ya!
              • #52
                thanks man...it'll be good next year when I have my power fc and some yellow jacket coil packs too...get a good tune and hopefully it will do well... very excited
                • #53
                  Plenum is finished polished and runners painted...heres a pic let me know what you guys think
                  • #54
                    Hey buddy did you go all the way up to 2000 grit?
                    Looks like a "brushed aluminium" look.
                    Next thing you should do is go buy some metal polish , you can get some cheaper ones from Crappy Tire .Next step is apply that to the areas that you want polished and buff the crap out of it,you can do it by hand but you'll get a better shine with a buffer bit on a drill.Trust me it will turnout alot better.I know how long it takes to polish those and it really sucks!Good job buddy
                    • #55
                      Yup all the way to 2000...but I wanted to be a little bit different so I did go with more of a brushed look....I didnt polish it at all so just wanted to do a little different than everybody else that has gone with the polished look....I already applied 3 layers of clear coat on top of this and im pretty happy with the outcome!
                      • #56
                        Car is back together now.....had one mild issue with stainless braided fuel line that was connected to my fuel filter it was broken and splashed fuel all over in the garage .....other than that the car is running abosultely normal...throttle response feels better than normal... I cleaned the crap out of the throttle bodies and hoped for not having a high idle because of it and it is running good....Dont know if i have any leaks from the plenum or throttle bodies yet but I will be checking that out tomorrow.
                        For the debate of taking off the ridge inside the throttle bodies for causing a high idle....this didnt affect my car one bit so I wouldnt be too worried about that being an issue to other cars but who knows...
                        Currently trying to find a good set of air filters for my car....still have the 2 maf sensors on right now and dont know what kind of filters I have on but they are destroyed and need some new ones...ordered up a set of K&N filters but have to modify the mafs and cut the end off so they will work ( end that has the 4 bolt mount for filters ) Hopefully it goes good and dont crack them.
                        Clutch should be here soon waiting for it to get here from Forcefed.....went with the Exedy Twin Carbon...heard good things about it so I decided to try it out.. Havnt seen any people using it on the forum yet so I will let you guys know how it is! Hopefully get it and install it in the next 2 weeks
                        • #57
                          just received my TIAL Q 50mm BOV in the mail today...pretty stoked. Just have to mount it.....hidden in the bumper by the intercooler or somewhere visible? hmmmm
                          • #58
                            It's bin a while since an update and I havnt gotten anything new its just sitting pretty in the garage Made up my mind on the clutch and should hopefully be purchasing it soon if xmas doesnt destroy my wallet....
                            Anyways a little inspiration to keep me motivated...its an old video but its what she sounds like
                            no racing, just cruisin, skyline running perfect running low boost for pump gas, supra is untuned and cannot/will not generate boost in this video but it doe...
                            • #59
                              gtr sounds niiiice! I thought the t51r was cool sounding but damn it sort of got me annoyed after hearing all that whine.
                              • #60
                                It sounds a lot different with a good tune....it was untuned at that point and he had just got it all together and just wanted to break it in a little before getting the tune done.
                                And thank you
