I've got 160k on my motor. The head and Pistons haven't been touched. I did the oil pump, drive and bottom end bearings this year. Even after countless track days & TAs the oem pump looked very good.
All of the things you mentioned above won't make a significant difference to making your car go faster. In actuality it's going to make things much more difficult because of the countless adjustments you'll have to deal with. The KISS method applies very well wrt suspension set ups early on. The most important adjustment is made on the nut behind the steering wheel as they say.
With everything you mentioned you're overlooking two of the most critical components to making the car handle better. The oem rear diffs can't take much track abuse. They overheat, wear quickly and subsequently begin to slip. The most obvious component(s) is tires. Pick up a set of R33 wheels and a set of 255/40/17 stickies.
All of that said I understand that people spend big money on their cars and taking their investment to the track is scary. In my mind it makes no sense on having a car with huge potential and pissing around on the street with it. Much like dating a super model on not wanting to "sleep" with her.
Do you have an oil cooler fitted?
