Thanks Frankie , thats what happened when i try to do build updates while sat at my desk at work on the phone :P , i corrected my inaccuracy !
So last night was up to 3am working on making things look like new again and had a new Ally to help with the work , a 9 litre pail of Kleenflo Carb and metal stripper/cleaner.
I grabbed a few other nasty looking castings to strip and threw them in the can of foul smelling liquid - this stuff is nasty - need to wear eye protection and a good pair of chemical proof rubber gloves for this .
and this
that was very nasty ..... and this
the shaft is rusty and badley pitted , not sure how to tackle this - will consult the oracle (google)
Now the throttle bodies came out of the wash tank looking pretty sorry still so i stripped them and dropped them in the tank of toxic waste , only gave them 30 minutes because i didnt want to destroy the seals on the throttle shafts and they came out nice and clean , I then removed the buttterfly plates and removed all the junk and stains with salvol polish. They are made of brass which is relatively soft so I didnt go too crazy as i didnt want to remove any metal .
Did one at a time so that they didn't get mixed up or put back in back to front.
This looks alot better
I used red locktite on the butetrfly screws - these are screws you definately DON'T want to come lose while the engine is running ..
Before these were cleaned you could shine a light behind and no light came through , now they are clean , there is a thin rim of light around the butterflies that will be eliminated with a coat of throttle coat from Tomei ..
The throttle bodies already had this coat on them but whomever applied it used it on the worng side of the butteryflys so it wasn't 100% effective
The throttle bodies were then masked up with frog tape and the corrosion and stains sand blasted off the outside with baking soda ...
after blasting , cleaned with brake cleaner ( i swear to god this stuff is the most used chemical in my work shop , i buy it by the case load ) , and then sprayed with fluidfilm.
When the aluminium casting has been blasted the metal is exposed and porous - this is a good time to seal it to protect the surface from corrosion . WD40 or fluid film is great for this , i soaks into the metal pores and does the job....
A quick blast of throttle body cleaner and its all ready for the assembly of the linkages and throttle coat ( tonights project ).
and this
...The throttle bodies were then masked up with frog tape and the corrosion and stains sand blasted off the outside with baking soda ...
