Intake manifold Rebuild ...........
Actually before we go down that road i think i'll cover the exhaust manifold install , coming from Toowoomba in Australia is the now famous six boost exhaust manifold . It is a true divided pulse twin scroll design that hopefully will improve the scavenging ability of the exhaust system to increase power , and also decrease spool up time. It weighs alot but is made from 3mm steam pipe so should last me a few years . Also came with all new stud kit and new nuts and stainless T4 flange gasket ( although i turn my nose up at this a little , looks like a cometic piece).
Time to install the studs into the head using antisieze - this ensures the exhaust manifold will fall off while on the track and give amny more hours of pleasure re-assembling things . ( oh wait , that was the dump pipes to the down pipe.... ) I jest really - antisize is a must on these studs if you ever want it apart again.
exhaust gaskets next - im using the ones that came int he nissan gasket kit , ill possibly replace with stainless ones at a later date but dont have a spare set at the moment ...
Screw the chsseburger - We can has 6boost ......
spread some Nissan RTV sealer over the threads to make sure it's watertight and assembled it ..
(It was also my first choice)
