I'll start off by saying this isn't really a project with high dollar performance parts all going in at once; its just a day to day work log of what I am doing to the car and what I plan to do with it.
This is a 1995 BCNR33 V-Spec, bought with ~86k on the odo.
For the intro, since I am lazy, I will copy my post in the 'Media' section in the next two posts.
My car came with the following when I bought it:
- Unknown Exhaust w/ SARD Cat
- Greddy Radiator
- Unknown Oil Cooler
- Greddy Oil Filter Relocation Kit
- Custom OEM Bumper w/ molded air outlet for oil cooler, homemade inlet to oil cooler, stock turn signals removed and aftermarket LEDs molded in
- Blitz SBC iD
- Razo Turbo Timer
- Ultra Digital Speed and Rev Meter
- 'Potenza' Shocks
- Aftermarket HIDs with lots of glare
- Aftermarket Steering Wheel
- Kenwood MiniDisc Deck
- Nismo Oil Cap
I got the Japanese manual for the following with the car, so I assume it is installed:
Nismo Sports Clutch Kit w/ Lightened Flywheel
Table of Contents:
Part 1
In Japan - Posts 2,3
Getting the car home/ compliance - Posts 4,5
Interior touchups/Installation of Mine's 320 km/h speedometer - Post 6
Steering Wheel Replacement/ Replace Boots / M's pod filter adapters - Posts 30,31
Compression Test - Posts 37,38
Side Skirt Fix - Post 39
Part 2: Twin Turbo Build - Garrett 2860-5s (Botched)
Parts list - Post 43
Nismo Oil Separator review - Post 50
Stock turbo removal - Post 56
Turbo Fitting Installation (O2 sensor, braided lines, elbows, etc.) - Post 64
Block Fittings/ Turbo Installation - Posts 69,71,76
Installation of Gauges - Posts 72,83
Oil Separator Installation - Post 73
Fuel Pump Upgrade - Post 79
Boost Controller Routing/Restrictor Removal - Post 86
Part 3: Single Turbo Build - PT6262 Journal Bearing - 495 whp @ 21 psi, Shell 91
Parts - Post 103
Twin Turbo Removal - Post 114
A/C Delete - Post 115
P/S Reservoir Relocate - Post 116, 136
Water Temp Sensor in Water Neck - Post 130
New engine overview/turbo mockup - Post 132
Tial Wastegates and BOV - Post 134
Blitz EBC Overhaul - Post 137
Turbo oil drain line - Post 138
Wastegate assembly and mockup - Post 139
Haltech install and wiring - Post 142
Tomei oil pan baffle install - Post 146
Reimax oil pump gear and sump reinstall - Post 151
Reimax gear material comparison - Post 155
Nismo Oil Separator drain for single turbo application - Post 156
Intake Manifold removal and install - Post 160
Oil filter block modifications - Posts 161, 162
Engine pull and transmission separation - Post 163
Nismo Coppermix Twin Install and 1st Fireup (Fail) - Post 172
Random Engine Leak Fixing (HG, Front Main, Cam Seals, etc.) and Reinstall - Post 173
1st tune - 350 whp ( fuel pump issue) - Post 184
Random photoshoot - Post 187
Fuel pump issue culprit, botched hardwire attempt - Post 193
6boost twin scroll manifold with SIngle Tial V60 wastegate install, Downpipe mods - Post 199
Proper Walbro 400 fuel pump install - Post 200
Nismo Quick Shift and Cusco Shifter Bushing Install - Post 202
2nd Tune - 495 whp @ 21 psi - Post 203
- Greddy Radiator
- Blitz SBC iD
- Razo Turbo Timer
- 'Potenza' Shocks
- Nismo Oil Cap
Table of Contents:
Part 1
Parts - Post 103
