Your work is bar none. Can't wait to see you make a pass next year. Hell i might even line mine up beside you!
Project.. !!FREAK!!!
Is that oil system assembly able to be used with a dry sump pump? That looks like a great idea and quality piece“Hey, come on, its a car right? No. It’s a symbol of your history, its a thread of continuity from which you came to where you are. It’s important that you don’t want to forget who you are.” -Dr.Phil in "Love the Beast"
Thanx for all the encouraging comments
I spent some time on the car and relocated the fan to the front of the rad which opened up everything so nice.
Also wanted to ask if anyone has there experience with the nylon braided hose vs steel braided.
Reason I ask is because I used the nylon on the pressure side of the oil system and I didn't like the extreme difficulty when hose ends were fitted. Had to pull the hoses back out to start the assembly.
I think I'm gonna redue them in Steel hose.
Favorites
lucky_cefiroentelijintyou\'re not listeningstop saying "yall"... i'm picturing you with a mullet.
mullet+skyline=*shiver* i dont even want to think about itOriginally posted by specialeditionHe ended up popping a tired and he failed at life.
No much of an update but thought I share a little project I did.
So a while back I bought a sport comp monster tach with the shift light from Oakville (Thx)
It was cosmetically damaged but functionally sound.
Being so large I didn't want it hanging off the dash so I installed it into the factory dash.
Sorry for the lack of tear down and build pics.
Shift light located on top of dash.
I'd try and give instructions as to how I did it but I don't think it would come across well in text.
Next ill try the oil pressure and temp gauges while trying to use the factory connections and replacing the sensors.Last edited by speedfreak; 08-13-2013, 03:17 PM.Favorites
wen i was talking about lag , I thought u had a 26 , my bad i saw u have a 30 , so good job mate
nice project
y dident u go wit more agressive camshaft to try to push the power till further in the powerband ?
not hating ,i love your custom build, just asking question
Cheers
Lucky GTR
Thnx Lucky
My decision to stay with the less aggressive cams was because I am using the rb30 crank with the stock main girdle.
RB's have been said to not like the higher rpm range above 7500-7700 and more aggressive camshafts make there power higher so that is why I went with the type B cams and springs.
Your Nitto crank is a sweet piece and is defiantly built for high revs.
Did you buy the billet mains also from Rips?
How high of RPM did Rob say you'd be safe to go to?
There's a guy on YouTube with a Gtr called El Toro running a 3.2l also
http://youtu.be/T4ZHJE0hbBQ
I think you will be the only and highest displacement RB in Canada!!
Best of luck man!Favorites
Best of luck man!
I dident Get BILLET main , ROB told me he ran 6 sec wit stock mains, so y bother ,
yeah my rips engine is pretty sweet , motor is ready for 9500 RPM,
Head has TOmei type b spring n retainer so ,.9500
TOMEI Pump 10 000rpm
nitto 3.2 stroker block =10 000 rpm capable and 1600 hp ,
so i will just see what the dyno says , if the motor still makes power till 9200 RPM , well that will be the red line :P
if its 8800 well 8800 rpm will be my red line ,
but the motor is definitely ready for 9000 rpm EAZY EAZY ,
cheers buddy , and u have a swweet build too
yeah i saw this guy , Makes full power at 6000 rpm but only rev to 7800 rpm , maybe is cam setup
but he gets fulll boost fast ennuf 5200rpm still ,
neways i cant wait to see my OWN number
Originally posted by LuckyGTR View PostI dident Get BILLET main , ROB told me he ran 6 sec wit stock mains, so y bother ,
They have RB26s running 9, 8 and 7 quarters to0 so y bother with an RB30, let along a stroked 3.2. What's that cost $5k more than a built 26? Then again, something to brag about I guess.No build thread.
1991 nissan
El terror
Actually, an RB32 is cheaper than a full counter weight 26. Unless prices have come down you are looking at $8500 for a 26 or 28 fully counter weighted. Even after the BS of the adapter for the pan and whatnot, you are still cheaper and have an engine with a much broader and workable torque curve. Unfortunately with mountainous torque you will break stuff more easily.
Lol bruizer ur a troll and dont know wtf u talking aboutOriginally posted by Bruizer View PostThey have RB26s running 9, 8 and 7 quarters to0 so y bother with an RB30, let along a stroked 3.2. What's that cost $5k more than a built 26? Then again, something to brag about I guess.
My car is not a drag car only its a street car that i will bring too the drag once a while
I went wit the fuly buit rb32 for the monster torke it will provide on the low and mid range power while still getting crazy top end
A rb26 at 900hp will lag its life before having some fun in the street
My point was really good , i dident get billet main , stock mains ran 6 sec on a full dragster
Y should i spend 4500$ more for no reason
Not trying to brag here not at all
Now keep on subject wit mr freaks project wich is a crazy setup and stop beeing a ***** wit yor bragggin
Kk tx
Originally posted by Dragon Humper View PostActually, an RB32 is cheaper than a full counter weight 26. Unless prices have come down you are looking at $8500 for a 26 or 28 fully counter weighted. Even after the BS of the adapter for the pan and whatnot, you are still cheaper and have an engine with a much broader and workable torque curve. Unfortunately with mountainous torque you will break stuff more easily.
Amen , a tomei rb28 is 8000$ for the good one
Plus n1 block 2000$
Plus , arp rod bolt, arp main bolts, arp head stud
Plus acl main n rod berings
Then labour and machining
Come almost to the same price
I paid 14.5 k for complete short bloc
Wit awd adapter plate / front timing cover / timing belt / arp head studLast edited by LuckyGTR; 08-19-2013, 08:58 AM.
