Project.. !!FREAK!!!
  • Project.. !!FREAK!!!
    So far from the day it all began I'd say its been a very
    positive experience working on my own car.
    Origionally the car came with a Mines ecu,an HKS timer and a stock drivetrain.
    So far the turbo timer is the only thing thats stayed in the car!!!
    Present Mods:
    Apexi Power FC w/Commander
    Sard 720cc's
    HKS AIC (Not installed yet)
    HKS SSQ's x 2
    HKS VPC
    Mallory 4port FPR 1:1 riser
    Bosch 044
    Greddy Catch x 2
    Irridium Plugs
    Greddy Timing belt
    N1 Water pump
    Samco Upper/Lower hoses
    Modified fuel rail to duel feed
    Eboost2 boost guage/contoller
    Warner EGT gauge
    Warner AF gauge
    Innovative Wideband w/RPM datalogging
    Toshiba Laptop (for road tuning)
    Recaro drivers seat
    Battery relocated to trunk
    Top mount single turbo manifold
    Garrett GT42R
    Custom 4" down pipe
    HKS wastegate
    Custom 5"intake pipe w/K&N cone filter
    Custom 3" piping to intercooler
    XS intercooler
    Vibrant hump hose
    HKS Triple plate clutch
    Redline oils throughout
    Filter Relocation kit
    Torque split controller
    3.5" Cat back system not sure of the make yet but will do
    a back pressure check to see if its too restrictive
    With all these mods I know I was running in the 480whp
    range @ 21psi on pump 94octane.
    New Mods already in progress:
    All Stress rises removed and polished
    Jun Crank collar
    Micro polish crank journals
    Removed "Bulls head design from Counter weights"
    Replace all crank oil gallery plugs
    Balance crank
    Balance clutch
    Check balance of new Ross Harmonic balancer
    Stress relieve and Cryo crank
    Block has had all the casting flash remove for stress relief
    N1 oil pump
    15 row oil cooler
    Argo "I" beam rods
    86.5mm Wiseco piston Teflon coated skirts and ceramic tops
    ARP Head studs
    ARP Main studs
    ACL Bearings
    Custom oil baffel
    Tomei Gaskets
    Tomei Poncams
    Tomei Valve springs
    Tomei Retainers
    HKS valve seals
    STR Cams gears
    STR fuel rail
    Nismo engine mounts
    JJR torque mount
    Combustion chamber work
    Port match and polish
    Tranny is an OSG type "A"
    Larger R34 Koyo rad
    Future upgrades.....
    BRAKES I NEED BRAKES......(Most likely VTTR's)
    Brake master cylinder and stopper
    2nd Bosch 044 and fuel cell or swirl pot
    Rims may need to go to 18's for caliper clearance Bee R's in white or Polished
    Roll cage that reasonably street usable
    Subframe braces custom fab
    Chassis reinforcement
    Ohlins Coil overs
    Heres the car when I got it in 2005 December
    The Stock engine
    Detailed the engine bay with a few mods already started
    Single Turbo
    Custom inlet pipe and K&N
    Custom 4" Dump pipe & Wastegate
    HKS Triple plate
    Mallory FPR
    For now I'm waiting on the bottom end parts and machining
    Its been at least a month since it came off the road and all I want to hear is it running again gonna goes nuts this winter :hit_head:
    Favorites
    lucky_cefiro
    you\'re not listening
    entelijint
    Beautiful car! What did you do to get your engine bay from "typical" to WOW!
    Someone mentioned to me to wash the engine bay down with WD40?!
    '08 HD FXSTB: Denim Black, V&H Big Rads, V&H Fuel Pak, K&N, HD Inverted Front End, C&C Seat
    '78 HD 93" Shovelhead rigid, 4spd, 3" open primary, 250 rear tire, 40 rake. (in progress)
    '90 GTR 2 tone 350z blue/black, Volk TE37s, Greddy intercooler and suction kit, Blitz BOV, Splitfire coils, Greddy gauges, HKS oil filter relo / oil cooler, Rear LSD, HKS hypermax II suspension, soon to have new turbos.
      Never heard of the WD40 this..hmm
      I used an engine shampoo from ACDelco
      works better than any other stuff I've ever used before.
      Then I use an engine dressing let it soak in then wipe off the excess
      We buy this all our stuff from Redstallion which supplies to dealers it works to rejuvinate rubber.
      Last along time too.
      Its kinda like the clear Simonize Tire dressing but not as thick.
      Favorites
      lucky_cefiro
      entelijint
        Very nice indeed. If you decide to get new rims, go for polished finish.
        1989 Skyline GTR
        www.victoriamotorsports.ca
          Speedfreak, you're running a GT42R on a stock engine with stock displacement? You must be a whiz at tuning! :shock:
          Out of curiosity, when does it come on, and how high are you revving to?
          2012 Deep Pearl Blue Black Edition GT-R
          Some say my teeth glow in the dark...
          And that if you tune your radio to 88.4 FM you can actually hear my thoughts...
          All we know is, I'm called The Stig
            i can get you vttr brakes at a price no one can beat..let me know !
            All parts sold are no refund/exchange
            Honda tuning is a LifeStyle
            Goals for 2013
            Get the dAmn thing rUnning
              Dr. GTR
              Tuning was always something I hadn't got to do much of but most of my carrer in the automotive trade has been in engine management related dept aswell as the grunt work.So tuning my own car was my way of testing my own knowledge as a Tech
              As long as you have the right tools to read whats going on the PFC is a very user friendly standalone.
              I know that I pushed the limits of some of the key weak spots in the RB26
              cause when I took the engine apart for this build items like the headgasket showed fatigue in the fire ring-coolant passage areas.
              So those wise old men who say that there are known limits to certain parts of our engines Definately are Wise old Men.
              I think the stock internals could go even further if bolts/bearings were changed up.
              I'm not going to stroke the motor as I like the over bore design for RPM HP like Mines's does.
              I am going to 87mm bore for some displacement increase.
              Felix your gonna be my source for VTTR's for sure!
              can you tell me if the 330mm setup or 350mm setup will clear the rims on my car? Do you have a printable template to download for checking this?
              Favorites
              lucky_cefiro
              entelijint
                Well, it's definitely a testament to your tuning ability that the car is running so well. Kudos!
                Again, for my own curiosity, roughly when are you experiencing the turbo coming on, and when do you hit full boost? Is 8000 RPM still the limit for now? The reason I ask is that I wouldn't mind a single (obviously nothing in the league of the GT42R), so I'd like to hear how the biggest of the big ball bearings do with stock displacement.
                  Boost starts at 4200 rpm & is full at 4800rpm
                  I set my PFC redline to 8000 and no issues but it still made me nervouse to take an unbuilt motor beyond 7500.
                  plus the oil pump issue was always on my mind so hence the reason I didn't just continue to drive the car for too long,plus it allowed me to have and already tuned ecu for when it gets reassembled
                  I actually considered modifing the down pipe so I can swap a GT40 or 4088r on with a lower turbine A/R for road coarse use.
                  we'll see how it responds next year before I do that!
                  Favorites
                  lucky_cefiro
                  entelijint
                    Here's some pics of the prep work on the block for oil control and stress riser removal.
                    Favorites
                    lucky_cefiro
                    entelijint
                      is it a 102 or a 94?
                        mcfly
                        As Alex Trebec would say
                        Please give your answer in the form of a question.
                        If you talk'n fuel it was tuned with 94octane
                        Favorites
                        lucky_cefiro
                        entelijint
                          oh no i was talking about the exducer on the compressor side.
                          102mm or 94mm
                            OHHHH!!!!
                            Its a 94mm with a 1.01A/R turbine its the GT4294R
                            Favorites
                            lucky_cefiro
                            entelijint
                              Really nice build. looking forward to updates.
                              did you use fc-datalogit, if so did you have any problems getting your wideband to interface with the AN inputs on the datalogit. I cant wait to get mine on the dyno its the part I am really looking forward to doing.
                              Trust T618Z,Carrillo Rods,CP Pistons,Tomei 280 10.8 lift ProCams, Tomei Spec C Springs, N1 Block, ARP, ATI, ATL, Bosch 044,Sard 800cc,PFC,Z32 etc.......
