BOV install for GTR
  • #31
    Does anyone have a pic of a one BOV conversion? The two recirc valves are in SERIES, not parallel, so I dont see why one big single wouldnt work
    • #32
      HKS SQV BOV's kit for the GT-R 32-34 is using a single blow off valve. The kit includes a stainless piping w/ the HKS SQV attached, it's a direct bolt on and will be positioned beside the battery. I'm using one actually.
      • #33
        Its not a GTR but my friends FD has a single HKS bov on a twin turbo set up. Spools and lets off a nice high pitch sound. Might not be the same since I dont think FDs have a recirc system. So it has a MAP sensor instead of MAF.
        • #34
          Twin turbo FD? Wow, good stuff
          • #35
            I run a single ARC blow off valve on the TB side... No Recircs, No problems.
            • #36
              Im getting the re3cirst valve housing welded now and ill pick it up when its done, here my rough plan, ill throw up a pic when its done. Im just capping one of the flanges and welding on the Tiall 50mm so the cut end
              • #37
                I do have one question though, when doing a single conversion, did you just cap one of the small vacuum lines that were on the top of the recirc valves? Does only one of the small black hoses handle the pressure fine? Im referring to the two hoses hanging down in the pic right above this post.
                • #38
                  I'm pretty sure both of those T off of the same place...
                  • #39
                    i was looking at that too what did you have to do with the other stock bovs or is it just bolt on and it works?
                    • #40
                      The oem blow offs were removed, put it in some box some where. It's just an easy bolt on.
                      • #41
                        Can you buy that hose adaptor separately? Can I use one for the Tial 50mm? I LOVE the look of that chrome
                        • #42
                          Thanks. I don't know if HKS sells hose adapters... but I can't see them advertised in their product line up though.
