The Never Ending Project..
  • #31
    i feel your pain man!
    the way im being treated....i wouldnt expect this anytime soon but, then again....thats good ol' TSS at their best again.
    .......GTRCANADA.COM
    Canada's premier Skyline enthusiast club
    • #32
      They are starting to disassemble the car now... :|
      I wonder what we will find....
      • #33
        my guess....
        rings are shattered
        crank bearings look like mushrooms
        and pistons may be damaged in the process along with the cylinder walls.
        hope not....but....owch
        • #34
          How long ago was the engine rebuilt? Also how high was your compression ratio?
          • #35
            They never rebuilt it... I'm not sure what the comp was.
            • #36
              You should really watch the compression. High compression + Low boost = Perfect setup. Basically when your adding more boost to a high compression motor it's being turned into a ticking time bomb. I'm only running 12 psi, I dont think I would ever want to run 15 psi as a daily driver. Boost can make up for bad compression.
              • #37
                We are looking at lowering the lowering the compression... First step is a thicker head-gasket.
                I am open to ideas, if anyone wants to pitch me some.
                • #38
                  sounds like you are having a heap of bad luck on this project?
                  whats Steves take on this, he must be pissed or just frustrated outta his tree?
                  • #39
                    Little bit of both... lol
                    • #40
                      i say you swap your rb20 back in
                      jk
                      Go forged internals, thicker head gasket, lumpy cams, change your plenum to the stock rb26 one or the greddy one. and get a top mount. If your wallet will allow it
                      • #41
                        Ok... the rings are not damaged, but we are replacing them anyway. The cylinder walls are fine as well. I do however have two fractured pistons. We are exploring the cost options for replacements...
                        Forged pistons, and a thicker head gasket. Likely doing the bearings as well, with stronger rings. The Steve and his shop are being gracious thus far, and I hope I get her back for at least part of the summer.
                        • #42
                          Settled on a 1.2mm metal head gasket, forged pistons/rings set, and bearings. good start I believe... Honing out the cylinders now.
                          • #43
                            Good choice, nothing wrong with the 1.2MM headgasket. That's what the turbo motor was designed for and should be 8.5:1 compression. I wouldn't want to go lower than that because you'll lose a lot of low end torque and flow =\. I also chose a 1.2MM headgasket for my build but used a tomei metal gasket.
                            Knowing how my GTR build is going you'll probably be back on the road quicker than me =\
                            • #44
                              I was advised first by the shop to get a 1mm metal headgasket... it was installed when it fried. lol
                              • #45
                                can stock pistons handle 400 HP?
                                just curious?
