Block is at the machine shop, and i picked up a rb26 crank and set of rods from 'the green bastard' himself. I own you one.
The Quonset Project
Finally tore out hicas.
Also ordered a ton of ****..
-Top mount fuel rail
-Injector resistor
-ARP head studs
-Oil pump
-Water Pump
-Full gasket set
still need
-metal head gasket
-pistons that fit
-bearings
-timing belt
-idler + tensioner
-clutch
-hicas lock bar
-crank collar
Way too much **** arrived.
-ARP head studs
-Billet aluminum fuel rail
-rb26 440cc injectors(for a start)
-walbro 255lph fuel pump
-hicas lock bar
-water pump
-oil pump
-nismo adjustable fuel pressure regulator
-timing belt
-full gasket set
Still much more to come.
I finished with the complete hicas removal, minus the lock bar. I rerouted the hicas pressure line from the pump to the 'p/s cooler' then back to the reservoir. So i dont need a non-hicas p/s pump! Still need fasten some of the lines down. Also, started putting back in some of the wiring harness.
Did you get those parts from Phase2?
Also I can get the following for you if your interested. Shoot me a PM
-metal head gasket
-pistons that fit
-bearings
-timing belt
-idler + tensioner
-clutch2009 Mercedes C63 AMG. Daily
1969 Cooper S. Restored
in the pic of the two P/S lines, which lines are those... return side or Preassure side. becuase from the pic it looks like regular ole fuel line sort of thing. and we're talking high psi number for Power Steering systems. it would blow those in about 5seconds. ive seen it.
OR!
I just cant tell from the pic that you used something that will work.1989 GTS4....
Finally a ******* update.
Will have the block back from the machine shop soon, so the build begins next week. **** yeah.
Got a GTR fmic for a good price, as well as a diy piping kit. Thanks Rickieroo!
Not happenin:
Tore out this:
Made some brackets out of this:
I threaded one of the mounts so i could throw a nut on to fasten the rightside bracket:
Test fitted:
Painted:
Im gonna use rubber washers/grommets to dampen them vibrations.
Cool beans - I'll be getting my GTR FMIC next week!!
I hope it comes with those brackets...I'm also trying to think of something funny to paint on it like JDMFTW or something...Or maybe just R32...or....maybenot.
Looks good though!Fraser Valley Imports
Cars:
2007 Yamaha FZ6 Custom
