Originally posted by frankiman
View Post
Gt30 rb20 build - 1 Year Project + Paint Job Pictures
just saw this thread for the first time, nice paint job!!
i love the blue lipped rims with the matching rays nuts
small update changing turbo
Garrett GT2864R
Turbine AR: 64
T3 Style Dropin Replacement
Larger T04E CompHousing With 4 Inch in, 2.5 inch out, No Wastegate actuator.
38mm External Tial Wastegate
thanks to Skym from another thread, this website was very helpful
No Limit Motorsport is the performance parts specialist you can trust. With over 20 years in the aftermarket performance parts and accessories industry, there is No LImit to your rides potential.
i think this will be a better setup, quicker spool with reasonable power output.
Any thoughts?
thanks mike, ya i am going to try to do some of the stuff on my own, but stuff like headgasket and studs, you and andrew are going to help me out.
mmm I consider this my second project car.
Keep up the good work Jakub, that MAF is waiting also
Would be much appreciated, thanks.
Were all learning something new everyday about our cars, nobody knows everything, including me.
Where I am, don't have access to a NAPA store.
1inch = 25.4mm. At least that's what it says on conversion chart I have.
76mm / 25.4mm = 2.9921 inch or roughly 3 inchs, which like you have already said, doesn't look long enough.
i take some pictures for you, but i am not expert on Bovs. mine came with like a wide adapter thing on the bov end where we attacked a rubber hose from napa + silicone rad hose and made a join from bov to the re-circ pipe. It idles at 850rmp when engine is warm.
Edit. ya you don't need a specific cuppler from synapse, just make your own, it works fine.
ya 7 cm is way to short, now way it will make it
I never doubted the mines GTR.
Where there's a will there's a way.
But on that note, it will come sooner if you save your money now
I see, thanks.
From what I can see from construction diagrams, Synapse BOV doesn't use a diaphram, it uses O rings. Sometimes if O rings aren't lubed when installed, they can break or be damaged and not seal properly.
I thought Synapse BOV needed a different recirc joiner, as I measured stock BOV recirc fitting at 29mm / 25.4mm = 1.1417 inch or so. So stock rubber recirc joiner won't fit over a 1.25 inch x 25.4 = 31.75mm fitting. Would have to buy their recirc joiner. Just as well, as I need to replace that joiner due to stock intake hose clamps producing cracks in that joiner.
Here's the 1.25" silicon hose joiner on their website -
Do you have rough idea on length of that joiner, as 76mm might not be long enough???
What did you do for boost feed???
i have a practically brand new nismo twin plate and its fine for my application.
snow i will be able to get the Mine's Gtr if i get into a career sooner or later, its still a few years off and i am both working hard and being optimistic. I gave up on the whole lottery thing lol.
