M13, yea that definitely seems to be the best bet at the moment. I'm going to keep looking around for a place to do a rebuild in my area before i think of outsourcing. Would be nice to go with someone who's tried and true, so that this at least doesn't happen again lol. New would be amazing, but to justify, like you said, 2000$ on an HKS 2530 or something is a bit ridiculous ATM.
Skym, when i received the turbo there was a noise but insignificant in terms of thinking it was due to the ball bearings > journal bearings i'm used to in my rb20. At any rate, there was sufficient play IMO to have caused this in the long term, only because any sign of up and down play may, or will result in some unbalance at full spool.. I'm going to assume that the previous owner either ran low oil psi due to failed oil pump, like you said, cas off the crank, low or no coolant or perhaps there was a blockage to justify starving it until the bearings picked up a small whine, at which point he sold..
Both wheels shattering is definitely a failed bearing, and the bent shaft would have resulted from the turbine wheel getting smoked then following suit. There really isn't much more i can gather from this other than it never lasted over 12 lbs of boost, so to assume a wheel went that soon, with ambient temps at around 5 celsius, exhaust temps must have been fairly low, coolant and oil were low in temp as well with significant oil pressure and new water pump etc.. Very strange!
Hi-flowing it at this point would be ideal, as i can also select trim and CHRA to use for my specific intentions. It's too bad the "South" isn't any closer, otherwise it'd be worth the effort to have it sent or even bring it myself to have it done to save on the shipping cost.. Could potentially make a good vacay out of it heh. Skym, you'd have to show me the car scene in Aus Land!
Just gotta pay to play.
