Engine fluid quantities?
This is a sticky topic.
  • Engine fluid quantities?
    Hope I'm not reposting anything here, but I searched here and SAU. I'm looking for all the amounts of fluids that the car needs.
    So far this is what I'm planning on buying
    Brake fluid - Motul RBF600
    Trans fluid - Redline Heavy Shockproof
    Front diff - Castrol SAF-XA (weight?)
    Rear diff - Castrol SAF-XA (weight?)
    Gearbox oil - Redline MT90
    Transfer case - Nissan Matic D
    P/S fluid - Nissan P/S fluid (dunno about part #)
    If anyone has any info for how many liters of each I'll be needing, that would be great, as well as any other suggestions.
    Thanks guys
    Dave
    The trany takes 4.1 litres of GL-4 75W90. I used Royal Purple.
    The front diff. takes 1 litre 0f GL-5 85W90. I couldn't find synthetic 85W90, so I put in Redline 75W90.
    The rear diff. takes 1.5 litres of GL-5 LSD 80W90. I put in LSD 75W90 from Redline.
    The transfer case holds 1.8 litres of Nissan automatic.
    Not sure about the others you mentioned.
    1989 Skyline GTR
    www.victoriamotorsports.ca
      very good information as I will have all fluids changed once car arrives
      anyone did the whole change and can add to the list already posted on how many litres it takes of each and maybe cost?
      VVVVVVVVVVVVVVVVVVVViper!
        stickying . . .
        marginally literate keyboard warrior
          Anyone heard of Amsoil?
          I know a guy who is a dealer for them, its all synthetic, just wondering if anyone has had any real world experience with it, I know they use it in racing.
            I use Swepco 201 for the LSD and tranny. This is used by a lot of the Porshe guys for racing applications.
            1991 Case 580K 2WD Extendahoe (aka "Brutus")
            2006 Ford F350 SD PSD Crew DRW (aka "Monster")
            2006 Kubota F2880 60" Mower & 51" Snowblower (aka "Buzz")
              I have used it with good results.
              BNR32 Owner
              Okinawa, Japan
                I did some reading on SAU today.
                The transfer case should take Dexron III auto tranny fluid.
                The rear diff has to have the LSD additive gear oil, while the front diff takes just regular gear oil, but will have no problems with the LSD gear oil.
                Dave
                  If I have a mecanical LSD (instead of Viscous) Can I use the same gear oil?
                  Marc-André
                  _________
                  2.2L RB20 GTS-T
                    I have no clue, try searching on SAU :?
                    Dave
                      I find it very hard to believe that you would be required to add LSD additive to the rear diff but not the front. The two diffs perform exactly the same functions, so why would they have different requirements?
                      The only difference between the two is that (on the R32), the front is rarely engaged unless you are pushing it. For that reason, the rear takes more use and abuse.
                      BNR32 Owner
                      Okinawa, Japan
                        Point noted. I was going to use the LSD oil regardless, since I have some extra sitting here from last week. 8)
                        Dave
                          What about engine oil?
                          Mobil 1 20w50??
                          or something else??
                          I'll look on SAU
                          Marc-André
                          _________
                          2.2L RB20 GTS-T
                            OK so I bought 5 quarts of 10w30 Redline sythetic 67$Txin at Canadian Tire
                            Yes yes
                            it was in the back store because in Qc your not allowed to have unilingual labels...
                            good thing we asked the clerk
                            here what they say on it:
                            and front:
                            Marc-André
                            _________
                            2.2L RB20 GTS-T
                              I just use Mobil 1 15 weight.
                              Race. Win. Live.
