Wow, That's a bummer about needing a rebuild! Especially since you were saying your engine had good compression and had a rebuild before! How many Km's did it have?
Mine is running great except for a possible leak in one of the many vaccum lines (slightly inconsistent idle)
Anyways, good luck with the rebuild! And you should take the opportunity to do a porting job while you're at it!
