When are you getting it back here, looks like it's pretty well ready to go??
crzyone's "project" car
Here is a post I made on another thread, explains why this is taking a little longer than expected. Thanks to Martin for finding all these issues before it could have ended badly.
Martin figured out why the commander doesn't work. It's for a later style Apexi than the one I have. He is borrowing one from a friend and will tune with that. Now I need to sell my commander and buy the correct one.So many problems to fix on this car. Martin is ready to hunt down and kill everyone at the previous shop for their work.
Where should I start... Missing starter bolt, missing transmission to engine bolts, missing front driveshaft bolts, broken shifter fork (which required dropping the transmission to fix), rear turbo oil feed line not installed properly (which involves removing turbo to fix), vaccuum lines not plugged on bottom of plenum, missing subframe bolt, and they dropped the engine/transmission without disconnecting the speedo cable which broke the 260km/h cluster. This build has been delayed quite a bit with these problems.
On the plus side, oil lines are on and motor has been primed. Makes good oil pressure. Guages are done. Car is basically ready to fire up except for some reason the hand held commander for the ECU doesn't want to work. They are waiting for everything to check out before firing it up for the first time. Should happen tonight or tomorrow if they can narrow down the problem.
Here are a few more pictures
Oil cooler installed. Knew those large openings were good for something.
Wheel spacers installed, much nicer fitment.
Interior finished
Pipe cleaner found in heater hose...
R32.4 GTR
I have a D-jetro and L-jetro with commanders for sale.Black 1991 GTR. Serious garage stand mantle/parts car.
the pipe cleaner was between the Crank case Vent on passengerr side and the turbo piping, it was on the back side of the restrictor. it broke off through the restrictor, and was left on the backside of it.
Levi, you forgot to mention the heater hose wasnt at all on the engine block side.
Well, a big thanks to Zulu, this evening I will be picking up the FCC3 commander, to talk with your GTR33L PFC, and he is also lending me his Datalogit.
+1 Zulu
Fast isn't Fast enough
It's a Weldon FPR, about the same price as an aeromotive. Bought it before I decided to buy an aeromotive fuel pump or I would have bought one. Has an aeromotive fuel pressure guage on it though.
Hmmm just looked at prices. The Aeromotive is actually quite a bit cheaper than Weldon.
Aeromotive
Weldon
R32.4 GTR
