Originally posted by Eber
View Post
Gtr Nismo #283
I just realized that last time I purged my coolant, I didn't open the nut on the exhaust side to drain the block. Maybe I still have oil in it because of the trapped coolant in the engine ??
What do you guys think is the easiest way to reach the drain plug under the rear turbo ? From over or under the car ?
I might still end up removing the turbos just to make sure everything is good. What do you think about reusing the exhaust manigold gasket and the misc washers ?
I don't want to spend too much on little things like that because like I said I'm going for a complete rebuild and upgrade anyway starting in August...
Thanks !1990 Nismo GtR #283
354hp - 292 ft-lbs
-"And I thought my girlfriend was high maintenance..." -Etienne
I just got through a turbo job on alex's GTR assassin. Your better off just getting two turbo's and swapping them completely. Make sure you dont loose any of the copper fittings. and buy the nissan gasket kit its like 150 bucks or so from ebay and it saves alot of time and hasle. We had to use gasket maker on alex's car so it has exaughst leaks X 10
SteveYou can't doubt the existance of hell when you live in it
Originally posted by BurlyR32 View PostHow did you make the needles red? As far as I know mine are now blue from the LED glow.
On another subject: look what I just got:
Bee-R kit coming up at the end of the summer1990 Nismo GtR #283
354hp - 292 ft-lbs
Dyno results
Just to get a baseline before really starting the build:
Best high boost pull
I love my french accent...
And the results:
low boost (0.8 bar):
High boost (1 bar):
I'm pretty happy about it. A good healthy 350hp.1990 Nismo GtR #283
354hp - 292 ft-lbs
Originally posted by Bern View Postwell I always knew that car was pushing 400 hp! At what boost was it pushing when it hit 350 to the wheels? 1 Bar?
I actually have another run where it pulled 354hp but torque was a little lower.1990 Nismo GtR #283
354hp - 292 ft-lbs
Originally posted by JDM-IMPORTS View PostWow that's our old Nismo from several years back...
It has N1 turbos (steel wheel) and an N1 block...1990 Nismo GtR #283
354hp - 292 ft-lbs
It has N1 turbos (steel wheel) and an N1 block...SOLD:1990 Skyline GTR Nismo #283
