Update.
Finally picked up an HKS fuel rail to replace my Tomei one (purely an aesthetics decision at the time) but it seems that the "badass" hKS one has a smaller bore by 5mm meaning it could very well be smaller than the OEM rail (had it bigger fittings). So I don't know if I'll use it. I figured, it's nearly 2x the price as the tome, should be better..... not?
![](http://i190.photobucket.com/albums/z132/Franc_Bruizer/photo-48.jpg)
Some more powder coated parts came back. Looks nice IMO. Started throwing in the bushes and attempted assembling the subframe a bit more. Seems I'm hung-up in the rear lower control arms, they don't seem to fit as intended.
![](http://i190.photobucket.com/albums/z132/Franc_Bruizer/photo-49.jpg)
![](http://i190.photobucket.com/albums/z132/Franc_Bruizer/photo-50.jpg)
![](http://i190.photobucket.com/albums/z132/Franc_Bruizer/photo-51.jpg)
![](http://i190.photobucket.com/albums/z132/Franc_Bruizer/photo-52.jpg)
Then came the ball joint confusion. The spherical ball joint is totally different by meaning it doesn't even fit the knuckle properly, it is a Driftworks R32 piece which was said to fit the GTR (not the fronts though)
![](http://i190.photobucket.com/albums/z132/Franc_Bruizer/photo-53.jpg)
Here is the new lower control arm
![](http://i190.photobucket.com/albums/z132/Franc_Bruizer/photo-54.jpg)
and the old lower control arm
![](http://i190.photobucket.com/albums/z132/Franc_Bruizer/photo-55.jpg)
There is enough play that I can't see it being an ok thing. Yes I can torque it down to stop moving but a little driving and my alignment could go up to 5mm more or less negative camber (depending where I mount it)
![](http://i190.photobucket.com/albums/z132/Franc_Bruizer/photo-56.jpg)
![](http://i190.photobucket.com/albums/z132/Franc_Bruizer/photo-59.jpg)
Here you can see how much play there is in the bushing sleeve (or whatever it's called), without the nut
![](http://i190.photobucket.com/albums/z132/Franc_Bruizer/photo-57.jpg)
![](http://i190.photobucket.com/albums/z132/Franc_Bruizer/photo-58.jpg)
The HICAS delete kit was also a bit off. The outer bracket has a 3mm wider opening that the bushing that came with the kit. Do I just torque it down and deal with a bent bracket or is it supposed to have retarded amounts of play?
I know I cheap'd out by going drift works (was only $1800 for everything) and not Ikeya ($3K+) but before I get mad and throw the lot in the garbage, anyone have some ideas?
