so last update i started fixing rust and prepping for paint.
i did miss alot of work with this camera. i made the mistake of leaving it behind the plastic when i did my poly paint booth.
might do a recap after this. just barely done paint. still quite a bit of work left tho.
first thing i did was work on driver side. this is after all the old stuff was cut out and new metal welded in.
heres what rust on passenger side looked like.
and cut
and new started to tack weld in.
and after i fully welded it. first coat of filler.
more rust on drivers side.
then cut out. and look at the crap that fell out :/ i somehow missed the pictures of the fix tho.
then pulled my driver door out. the wiring was messed. it kept popping fuses. and if you can see someone tried to make the door lighter by butchering it.
i had saved doors from my black car. only one little dent on it. also received my Greddy body kit and started to fit it.
then after that is when i sealed camera away. when the paint booth came down. this is the result.
then starting some install after a couple days of drying
started fitting the diffuser properly aswell
then it was time to drive this baby outside for first time in months. the color choice still blows my mind
it changes so much in the light. here it almost looks black.
then it was time to cruise. but it was night. ive had these sitting around for a while. install was super simple
looked amazing at night. everything blue now.
lots more updates to come. tons of pics. had 2 buddies bring their really nice cameras.
and cut
technically free skyline.
cant wait to get it back.
