Wideband is done, wstegate is on. Realized I also gota make a dump pipe as it points at my block lol.
Project Modworks Monster R32 GTR
1992 BNR32 Skyline
Current Build:
Precision 6264 Turbo 1.00A/R
Tomei PonCam Type B
Manley Titanium Valvetrain
CP Pistons / Manley Rods
N1 water pump / N1 Oil Pump
Haltech Platnium Pro
AEM Water/Menthanol
Tomei FPR
Exedy Hyper Twin Clutch
Build Thread
Okay its all finished. Car si together and starts
Ill get some pics/video tonight. Unfortunately my Hand Commander **** the bed last night completely, and I had to order a new one, should be here Wednesday. No tuning until then because the Dataloggit and the LapTop wont read any sensors without the hand commander plugged in.
1992 BNR32 Skyline
Current Build:
Tomei PonCam Type B
AEM Water/Menthanol
Tomei FPR
Build Thread
what really? i can do everything without my commander.. thats odd.. sure thats the problem?
just making sure you are familiar with datalogit. i didnt think my "monitor" page worked either. but it doesnt show up untill you click "log start" if you arent logging. you cannot read anything or see your tracer in the maps.RB25 Powered RWD GT-R
Really? I have a friend who is very familiar with FC Edit, and said on his RX7 no sensors will read without the hand commander plugged in and working. And then for my own benefit, I plugged my stuff in with and without the broken hand commander, and it worked fine fot basic fuel/timing modification, but wouldn't read any sensors lol. I ahve a new old style hand commander on the way here, Apexi USA had two left for cheap
1992 BNR32 Skyline
Current Build:
Tomei PonCam Type B
AEM Water/Menthanol
Tomei FPR
Build Thread
Yea it's water and air temp I was looking for, and I can't seem to get my innovate mtxl wideband to show through fc edit either. I have the yellow (0-5v) signal wire going to an1 and an2 hooked up to the same ground as the wideband itself. I have the delta option selected and the 0-5v parameters set as per the instructions. I start a log as can't see on map trace or add a each for the an1-an2 wideband option. When looking for water and air temps, all the basic options show 0, but I noticed tonight the advanced options show numbers. I'll try again tomorrow with a couple guys who know wtf they are doing with the fc edit. I can't seem to figure out the wideband. I have it set the same as my rx7 buddy, and his works flawlessly lol.1992 BNR32 Skyline
Current Build:
Tomei PonCam Type B
AEM Water/Menthanol
Tomei FPR
Build Thread
1992 BNR32 Skyline
Current Build:
Tomei PonCam Type B
AEM Water/Menthanol
Tomei FPR
Build Thread
Ordered the AEM 30-3300 Water/Methanol kit today
unfortunately it will not be installed in time for the tune, so I will have to go back up again sometime. #safetyfirst lol
1992 BNR32 Skyline
Current Build:
Tomei PonCam Type B
AEM Water/Menthanol
Tomei FPR
Build Thread
dyno results today were 365whp/207wtq. Having issues with some kind of driveline drag, car cruises at 0psi vac/bst prsssure.1992 BNR32 Skyline
Current Build:
Tomei PonCam Type B
AEM Water/Menthanol
Tomei FPR
Build Thread
You certainly are having issues. I made that with a totally stock motor, PFC and boost controller.
I'll be in SJ Friday-Sunday if you're around. I could have a look if you like. Not saying I can solve any probs but sometimes another set of eyes helps.Last edited by bobbo; 08-18-2014, 10:23 PM.
I would love it if you stopped by! i just ordered a new 53mm rad and dual 12" slim electric fans. my stock rad just blew up today
I dunno whats going on with the car to make sure low power, but i noticed since the rebuild the "ebrake" light has been stuck on for no reason. brakes dont seem to be overly warm or anything tho.1992 BNR32 Skyline
Current Build:
Tomei PonCam Type B
AEM Water/Menthanol
Tomei FPR
Build Thread
So i found two good sized boost leaks today. Tested all my coil packs (good) and did compression test 155-150-150-150-150-151 so all good too. Today i bought a set of HKS step 2 cams 272 and 10.2
I believe these needs head machine work done no? Also bought the haltech plug and play tonight. Should be a fun few weeks again.
1992 BNR32 Skyline
Current Build:
Tomei PonCam Type B
AEM Water/Menthanol
Tomei FPR
Build Thread
Got my boost gauge mounted today. Gonna go pick up my meth kit and radiator tomorrow i think.1992 BNR32 Skyline
Current Build:
Tomei PonCam Type B
AEM Water/Menthanol
Tomei FPR
Build Thread
So I got my 53mm GodSpeed Radiator installed, and after some slight PS modification, the two 12" slim electric fans mounted and wired with a relay to ignition. I have decided next week im gonna do the 12v mod ot my fuel pump as well. Also installed an AEM WMI kit, and Yellow Jacket Coils. Car is working much better now! Excited to hit the dyno again, and hopefully way less issues.
1992 BNR32 Skyline
Current Build:
Tomei PonCam Type B
AEM Water/Menthanol
Tomei FPR
Build Thread
