Felix it has been great watching this car progress. Can't wait to see the finished product.
Project Horny
This topic is closed.
cant wait till this thing iis running
ive been watching your build from the get go, even back when i didnt own a gtr.
are you going to sheild the valve cover?
are you going to sheild the valve cover?All parts sold are no refund/exchange
Honda tuning is a LifeStyle
Goals for 2013
Get the dAmn thing rUnning
Originally posted by felix yuen View Postwhat we have is a blanket for the turbo's exhaust housing. so yeah it's going to be sheildsigpic
Originally posted by FormerVDubber View PostWhat about using High Heat Ceramic Paint on the exhaust manifold. I think even Duplicolor has some stuff thats supposed to insulate up to 1200 deg. Of course maybe try to find some higher quality paint if you can.
costs maybe 100 for a manifold and you can do it to the exhaust housing too.
Also, you might want to take your cam cover and notch it slightly.
johns car as an example
Originally posted by mcfly View Postdont cheap out, get it jet coated or ceramic coated
http://picasaweb.google.com/tyndago/JohnsCar
we'll have to live with what we have and think of a solution when a problem arises.... Btw: it is not touching at the moment why do i need to notch it??? Is it because they will expend under high temp??.... Please explaneAll parts sold are no refund/exchange
Goals for 2013
looking good felix, seems you have had a lot of problems mate with this . i rebuilt mine myself and had no issues, sump adapter from proengines went straight on, front prop clears no issues, engine sits in and catches nothing at all?. ,..bernie uk .
rb26/30 gt35r 1.06 rear ceramic coated. jun stage one cams , cp forgies, spool rods, arp bolts everywhere. car made 700bhp @ 1.8 bar 660lbs torque @ 5500rpm. goes well.lol. really well.
Originally posted by rockabilly View Postlooking good felix, seems you have had a lot of problems mate with this . i rebuilt mine myself and had no issues, sump adapter from proengines went straight on, front prop clears no issues, engine sits in and catches nothing at all?. ,..bernie uk .
http://s212.photobucket.com/albums/c...ockabillyrb30/
well ur's is a R33 i assume it will have a bigger engine bay, so that would explain the turbo clearence issue.
i must say...ur parts are much nicer then mine..and that would also explain why ur install went so smooth... i mean ...look at ur manifold
i have spool rods too ....how's ur's?? what do you think of them ?
what are the specs of ur engine ?
just watched the vid of ur car...OMG....i can't wait till mine goes on the dyno and the track!!
thanksAll parts sold are no refund/exchange
Goals for 2013
What turbo are you running? Trust T88-34D?BNR32 Owner
Okinawa, Japan
Originally posted by rickskylinebnr32gtrjp View PostAre you going to be able to fit the blanket in between the housing and valve covers as well as the housing and strut tower? Please post a pic of the blanket. I was thinking about getting one for mine.
What turbo are you running? Trust T88-34D?All parts sold are no refund/exchange
Goals for 2013
Goals for 2013
