My car has a rebuilt S-Tune RB26. what are the odds that they addressed this issue when it was rebuilt in 2000?
BNR32 Oil Pump Drive Issue
This is a sticky topic.
I was just wondering if someone could explain to me how the boss collar gets rounded off if it isn't slipping from the pump drive? If the pump drive sleeves directly onto the boss collar without any gap, there shouldn't be any slip, and thus, no potential to round the edges of the collar off.
The only reason the collar would round itself off is if there's sufficient slip between the collar and the oil pump drive. And I think it's safe to assume that as soon as theres slip, there would be an immediate drop in oil pressure.
This is purely speculation but perhaps the collar was manufactured with rounded edges? Someone reply to me!Legend of the red R
i think i figured out part of why the collars dont always fix the problem
a friend and i were thinking of making some custom gears that are stronger material and we took some measurements of my crank collar and my oil pump
there was a total of .013" play between the collar (drive) and the gear face (driven)
now thinking about it most pumps fail at the limiter or at high revs due to vibration
.013" play is like a little jack hammer hitting the oil pump at the limiter or with alot of vibration. we are making a better fitting collar to address this issue. i figure if we measure thermal expansion of the collar and thermal expansion of the driven gear at say 200degF and factor in .001" press the pump should be near unbreakable as long as the engine is warmed up completely before beating on it. now the crank will be balanced also and a good damper looks promising as well. I'll let you know what i find out when we put it all back together
A little bit clueless
This might be an ignorant question... but assuming there is nothing major wrong with the engine, how much should one expect a rebuild would cost?1992 Skyline GTR - Garage Queen
2009 Dodge Caravan - Woopee
1989 240sx - Rusty Beater
1979 Nomad Skyline - 23' Camper Trailer
I wondered the same. After some intense search and with the help of FAST was able to find all i needed to know. here's my threadOriginally posted by Wedge View PostAnyone knows what production number the good crank 1993 GTR starts at .
As the title says, I need a starter for my R32. Here are two possible part numbers. 23300-20P00 or 23300-20P05. Both are the same but the 05 is the newer model. If you have the solenoid only, that's fine too as I really only need the solenoid, worse case. I broke a stud on the solenoid coil posts. Need asap.
hope this helps
Originally posted by r3gill View PostI wondered the same. After some intense search and with the help of FAST was able to find all i needed to know. here's my thread
hope this helps
Wow thanks i just stumbled upon your reply while searching for something and didnt remember i asked that question . I gave up on getting one a short time after that post i guess . Im trying lately to find a way to know by serial number on the engine if the motor is a march 93 or later engine or not so when i go hunting for an RB26 ill know whitch one has the collar and whitch one dont .Thanks alot for finding out the month
simply by putting your car's vin# into fast will help you figure which crankshaft you have. I'd be interested in finding out how engine serial # works.Originally posted by Wedge View PostWow thanks i just stumbled upon your reply while searching for something and didnt remember i asked that question . I gave up on getting one a short time after that post i guess . Im trying lately to find a way to know by serial number on the engine if the motor is a march 93 or later engine or not so when i go hunting for an RB26 ill know whitch one has the collar and whitch one dont .Thanks alot for finding out the month
going to toss up my thread on the oil drive issue. Its almost like a pop up book on the oil drive issue that EVERYONE should check out.
ALLEN PETERSEN
Number (604) 961-2449
RB30`s for sale!
