I would like to add two very important considerations to this post before people go out tearing their cranks out and fitting collars. There would be two reasons to fit a collar. One is to widen the drive, another is to reduce the clearance.
Reducing clearance is bad. The oil pump gears cannot be stressed by a crankshaft doing its thing, this can cause oil pump gear breakage. Forget about the slop caused by running loose clearences breaking the gears. There will be slop regardless with a flat drive system if you have the clearences required for this faulted system. .005" extra slop isn't going to make or break the gear.
As far as widening the drive goes, that can do two things. Spread the drive load to the entire width of the gear, or spread the damage to the entire width of the gear. It all depends how balanced your bottom end is, the condition of your damper, and how high you rev.
Having said that I have been running a narrow drive that has seen 7500rpm and plenty of rev limiter for 7 years.I pulled the pump due to low pressure (loose backplate screws) my oil pump gear and drive looked perfectly normal.
FWIW heres a pic of an oil pump gear ruined by a full width drive
The full width drive is NOT a solution, and not worth doing IMO. The full width drive still wants to spread the gears apart, moreso than the narrow drive as a matter of fact! Perhaps this is why Nissan engineers tried to narrow the drive on early GTRs.
The only way id pull the crank is to install a spline drive conversion. For now ill just keep my damper in check and make sure I don't rev past 7.5k
