REIMAX (Collar clearances, pics)
  • #76
    how is the splined drive gear attached to the crank?
    thanks
    • #77
      It is press fitted to tight clearance, All gears are made from SCM435 steel.
      Supertec Racing
      • #78
        I am about to put an order in for 5 more N1 gears, Priced at £430, if you guys do it as a group you should be able to save on postage costs, fully insured is around £60 to Canada.
        Supertec Racing
        • #79
          I don't understand. Does it press onto the factory crank flats?
          • #80
            No, as you would do with the jun collar, you need to machine away the flats.
            Supertec Racing
            • #81
              I'm not ready yet but I think at this point I'll be going this route.
              Thanks for posting.
              • #82
                thanks for explaining. sorry for asking too many questions.
                do you also drill holes for set screws?
                does the pump flow more than stock?
                • #83
                  No worries. Flow rate on the N1 remains the same, no need for screw as the it a very tight press fit.
                  Supertec Racing
                  • #84
                    Thanks for posting.
                    No worries let me know when you need a set.
                    Supertec Racing
                    • #85
                      I'll be in when I tear my engine down , hopfully it won't be for a while as it only has 30k on it
                      91 gtr , 93 rx7 type r and a multicolor 240 スカイライン
