Read this thread over and just wanted to mention that an air gap in the reservoir is normal as per the service manual.
Quote: "
CAUTION: After air bleeding is completed, a maximum air level height of 5mm (0.20 in) is allowable." - page CH-85
Just thought I would throw this out there since I read some people were concerned about an air layer in the reservoir.
On another note:
The bleeding process outlined in the service manual is a lot more involved then the ones I have read on the GTR Australia forums. Those don't mention doing anything inside the car besides disconnecting that one connector on the driver side.
Also, no mention of an air bleed switch on the forums like in the service manual.
Is if possible to bleed this from under the reservoir?
Have a VERY SIMILAR problem until I solved w/ the help of my boys from Tokyo. The culprit is... the Attesa Accumulator! You don't have to buy the whole expensive assembly just the small nitro charged cylinder tank (made by KYB).
And Ever wondered why the Hicas light flickers during the clicks? The simple reason is because our BNR32 Hicas is sooooo damn sensitive on voltage drops, that's why it is reacting if the Atessa relay keeps on engaging every 10 sec. or so. There is a thread in SAU on how to replace it. And we are more lucky actually coz some BNR34 owners are already having these problems, to think ours have it like 20 years later. lol. Here's the problem solved link from GTROC- http://www.gtr.co.uk/forum/131156-hi...d-trunk-3.html Good luck!
Right on that is a sweet link you shared! I'm going to try bleeding mine first and if the clicking persists I'll order the part.
Nissan part number listed on your link is: 41630-20U00.
Do you know where the KYB unit can be ordered from? No one has shared that info on the other forums, well not that I was able to find anyways.
Thanks!
Yes matey. Thru my good friends from Tokyo. Had to ask a favor from them since this canister may be under the "dangerous" item list in an air freight, coz of its explosive properties under pressure. They sealed it on nicely on the package and it did arrive on my door step safely. I'll send you PM of the supplier.
I was reading in a Skyline owners repair manual that I found online that you can download, and it said that it's the fuel pump relay and that its supposed to click every couple of seconds.
The Fuel Pump relay is different from the Atessa Relay at the boot. And it is more audible you can notice it as unusual or as the T.S said "strange" clicking sound.
alot of people confirmed that it's the nitrogen canister needing to be recharged or replaced on the atessa accumulator. Anyone know where it's located on the car?
Right on! Causing the Attesa relay to keep on clicking every 20 sec. or so on a very low charged accumulator. It is located, if I remember it right, on the rear differential. It is a small canister made by KYB.
