here is a tiny write up on how to cut a stock shifter (tons of pics). i was sick and tired of my car feeling like i was driving a semi and i wasn't gonna pay $500 for another shifter. soo given you have all the tools for the job, this mod is free. end result was it looks great and feels even better.
here is what the stock shifter looks like. so high i can use it as a damn arm rest.. and on top of that i literally had to look Around it when using my air con.. lol terrible
so you need to take a dremel or something and cut that top piece down the side in a couple places, then pry it open. Its kind of a pain in the ass and takes some messing around but the lower part will come out eventually.
i used a box cutter to cut the bulk of the bushing off and then i used a torch to burn the rest off until it was nice bare metal, clean it up with some sand paper after so its nice and shiny again.
then you'll have to grind down the end a bit so that a m10x1.25 die can fit on. i just used a demel with a sanding wheel on it and went to town until i couple get the die to grab by hand. then using some lubrication and a bench vice make your threads.
then install as per normal
it has a blue backing and the one in my car is blue so it should work.
