check what block you have! I'd love to find out...
Gtr Nismo #283
Craptastic !
Hey.
Finished putting the engine back in a couple of days ago. Engine cranks but doesn't want to start.
Check fuel, good. Check ignition, good. So what's missing ?? Air...Check compression: nothing. All cylinders under 50 psi.
I guess the engine is coming back out again. We'll see if it's easier the second time...
That Rb30 is getting more and more appealing...1990 Nismo GtR #283
354hp - 292 ft-lbs
-"And I thought my girlfriend was high maintenance..." -Etienne
**** **** **** **** damn **** god crap **** !
Little update.
Pulled the head today, look what I found on #4:
close up:
Is that a typical detonation sign ? As you can see #3 (on top) also shows some signs of whatever happened.
The head at #4:
What do you think ? I'll also post in the tech section.1990 Nismo GtR #283
354hp - 292 ft-lbs
I'd say unless you are hella patient and/or hella rich, stick with the RB26. Have you read what money can buy yet? 8-)
http://forums.gtrcanada.com/showthread.php?t=201782015 Audi RS7 Sepang Blue
2009 Yamaha R1 Raven Black - SOLD
2005.5 Audi S4 Sprint Blue Pearl - SOLD
1989 Nissan Skyline GTR - SOLD
Originally posted by tokes View PostYou should have your pistons before the block is machined.
Edit: According to manual, stock piston clearance is 0.035 to 0.055 mm or 0.0014 to 0.0022".1990 Nismo GtR #283
354hp - 292 ft-lbs
Yes, to match it up with the bore sizes.
I can't remember off hand what the clearance is on my Wiseco's, but since they are forged it is larger than stock. There are also manufacturing variances in pistons. Your set of 86.5mm pistons can have a few thousands variance in them, so it's nice to have them on hand to match up each piston to the bore it's going in.1990 Skyline GT-R - Jet Silver Metallic
It'll run someday
Makes sense.
Anyway the block is in for a hot tank followed by a magnaflux (see beginning of this thread for oil-in-prestone situation). It's not gonna be bored before another couple of weeks.
I'll buy the pistons if it checks all good. If not, well, I don't know what I'm gonna do. Start to prostitute myself maybe...:sick2:
Does wiseco provide the clearance with their pistons ?
Oh and my pistons are ordered by the way.1990 Nismo GtR #283
354hp - 292 ft-lbs
yeah wiseco includes a sheet with all your recommended clearances and ring gaps on there.
You were just talking about getting an N1 or an RRR block a few months ago, so a basic stock block buildup should be within your means financially :P1990 Skyline GT-R - Jet Silver Metallic
It'll run someday
It'll run someday
