Chapter 28 - Tuning sessions, dyno revisited
so on day 61, saturday, i had my appointment with Robin Almasi @ Almasi Tuning for a bunch of stuff
so i got up early on that morning, and changed out the cheap Castol GTX oil in favor of awesome Redline 10w40 full synthetic motor oil
put a total of 6 liters in it - the oil cooling system and filter relocator needs lot of oil to fill
then i took off the T-belt cover to have access to the adjustable cam gears
ready to go !!
normally, its a 18 minutes drive to Robin's shop,
so i left my place, drove slowly at first, then eventually had to get on some larger boulevards and drive ~70kph
the car felt sooooo unstable, the alignment couldn't be more crappy,
i had never been so scared while driving a car,
eventually got on the highway, drove up the 80~85kph,
then i started to ear something grinding somewhere, couldn't really point out what it could be,
i didn't really have time to think more about it when;
boom
a very loud boom, followed by 3 black pieces of whatever flying out the back of the car, 1 of them hitting the windshield of a minivan following me,
immediatly put on the hazards and parked on the shoulder (on top a darn overpass)
checked the oil pressure, ok
climbed out of the car and looked back, saw the pieces left accross the highway
ran in front the car and check everything, i really though my oil cooler had blown up, but it was ok
so i ran super fast all the way back where the pieces where, running across the highway to grab all the big pieces of plastic
walked back to the car and threw those in the trunk and kept driving to the shop
the fender liner on the passenger side wasn't tied up and was flapping in the wind, scratching against the road, when it cought a crack in the pavement and just exploded!
(the driver side liner was kept in place by my custom tow hook)
while i was waiting for Robin at the shop i grabbed this pic
also grabbed this pic of my really good looking front wheels/brakes assembly
a couple minutes after, Robin pulled up in his freshly paint -white- Suzuki Capuccino go kart
he opened the shop, and pulled out some cars;
a SR20DET B15 SER sentra
and a Race prep'ed Toyota Corolla Touring Car with an insane sounding straight pipe side exhaust
then i pulled my car in
then we started working on the electronics stuff
was needed to be installed;
brand new HKS EVC-S boost controller
brand new HKS type-1 turbo timer
brand new Skylab TSC
(eventually) AEM UEGO wideband gauge
so he took a look under the dashboard and was like; WTF?
"robin, i don't know wtf is going under there, i can't do wiring and i haven't touched that"
there was a huge mess under the dash
so Robin picked up a flashlight and scrutenized all the connections, harnesses, plugs, grounds, etc
then basically cut every useless thing out
after a little while, there was a huge pile of old computers and wiring on the ground, ready to be trashed
after that, we organized all the harnesses for the new controllers by passing them all threw the right places, most of it i had already prepared it
so he completely redid the whole wiring from scratch, hiding the boost controller and turbo timer computer modules behind the plastic panel next to the driver's right foot
everything looked UBER clean, no more wiring loosely hanging under the dash
yes my car was full of stuff, open boxes and manuals
up to that point, i hadn't brought the AEM UEGO gauge because i was going to install myself, but then Robin told me that having the O2 sensor already plugged into the exhaust system but without power to it, it could get it clogged,
so while we were setting up the dyno equipment, i called my girlfriend to go pickup the UEGO gauge at my home and bring it by,
by the time she arrived, the wheels were off and both the Dynapack pods were bolted,
so i handed the gauge to Robin and within seconds it was installed (i had already passed the sensor's harness into the car from the hole in the firewall)
then Mitch came around, he had been stuck in traffic for hours, poor him
so Robin finished setting up all the sensor onto the car, and the fan setup etc etc
it was already getting really late, considering it was a saturday night
so Robin started working his magic
power related performance parts at time of tune;
N1 twin turbos
Nismo 555cc injectors
Nismo fuel pump
Nismo fuel pressure regulator
Nismo thermostat
Nismo N1 water pump
Nismo radiator cap
Nismo downpipe, with Tomei heat wrap
Resonated cat-delete
HKS Legal cat-back exhaust system
HKS twin SSQV blow off valves
HKS EVC-S electronic boost controller
HKS 264° duration 9,5mm lift cams
Greddy / HKS I/C hardpiping kit
Greddy FMIC
Greddy / Power Enterprise silicon couplers
Koyo aluminum radiator
Apex'i power intake kit
Splitfire coilpacks
Divided twin turbo pipe
Adjustable cam gears
Custom grounding kit
NGK-R copper racing spark plugs
first thing to do was to try to figure out how to setup the darn EVC-S boost controller
Robin grabbed the user manual and probly worked an hour on it, doing some pulls every now and then, that thing isn't very straight forward
unlike other BCs where you simply input 16psi if you want 16psi of boost, with the EVC-S you select a duty cylcle between 0%-100%
the "response" setting between 0%-100%
another setting is the "overboost" which is a value in psi
another is the "warning" which is a value in psi
and the "boost drop" in 0%-100%
from the dyno screen, we were seeing very erratic boost curves,
so Mitch, Robin and I recheck all the boost controller plumbing and overall setup and it was all perfect,
Robin ended up finding a mix of settings that "seemed" to work, and went with that
so he tuned the ignition map on different boost levels, and eventually got 367whp at ~13,5psi of peak boost
he looked satisfied till i told him i got 382whp wit a peak of 13,7psi last year, something's wrong, how am i getting less power with the same boost??
we saw the boost curve dropping much more than before at higher rpms
after doing pulls for more than 1,5hours on the dyno, the engine plumbing was getting "hot", so Robin spewed a liter or two of water on the intake manifold to lower the IATs back down,
at one point, the CO alarm on the wall of the shop started to beep, WTF
we check it out and the CO level was indeed pretty high
one of the huge flex tube sucking the exhaust from the muffler was unplugged from the box, huh?
at higher boost levels, when the car hit the rev limiter, huge (loud) backfires came out the back of the car, that tube was aligned directly with the muffler and was getting knocked off the box, LOL
i eventually put one of my wheels behind the tube to stick it there
results
final pull boost setting (setting B on EVC-S) got 408whp at 6600rpm with AFRs pretty stable at 12, a peak boost of 17,7psi (yeah pretty high) with a total boost loss of 3.5 psi,
now, two weeks later, looking back on it, i know we weren't using the right settings at all, or not using the settings correctly
so i'll be going back and using the correct settings this time, i've figured it out
since that day, i've sent the car to Autoworx, to get the whole intake pumbing checked for leaks
i will also relocate the EVC-S boost selenoid closer to the ABS module to shorten the vaccum tubing length, to get a quick response from the thing
i've compared the dyno sheets from this year to last year's
at least the huge 17,7psi boost peak resulted in an enormous power increase of 60whp at 4500rpm
i will be back
AND I WILL GET MY 425whp (500bhp)
eventually, i left the shop at 9;30pm, on a saturday night...
it had been raining for the last 4 hours or so,
as soon as i got onto the on-ramp for the highway, i felt the car just sliding all over the place,
so i stuck to the right lane, with the hazards on, driving 50kph
till i saw an exit for Taschereau blvd, (which goes right by house), so i took the exit, but was 15kms away, with lots of stops and redlights,
everytime i hit the brake to come to a stop, the car went sideways, and the brakes squealed like mad,
lets say that i was attracting lots of attention of the other lonely drivers beside me,
it took 40 minutes to get back home, 9,5 hours after i left it, I WAS SPENT
ready to go !!
boom
N1 twin turbos
Nismo fuel pump
Nismo thermostat
Nismo N1 water pump
Nismo radiator cap
Greddy FMIC
Splitfire coilpacks
results
i will be back
