This guy has the same pump as me. I'm guessing it is an older model pump and that they did not mark them ten years ago.
1991 Skyline Gtr
hahaha ya your right, pressure is always correlated to volume, I just meant the pressure in THAT specific channell would be higher than in the channel of an OEM pump... from the photo Id say it probably is the HKS as you suggested... good pump!Originally posted by Super_Dude View PostArchaeic_bloke I dont think you understand the whole oil pressure thing quite right. Having a smaller/narrower passage in the oil pump doesn't increase oil pressure. Well, not where you want it increased. It would actually have decreased pressure (after the restirction) compared to one with a larger passage and identical flow rates.The SkyLife Community & News Website --> http://www.skylife4ever.com
Hell Yeah. Do it right or don't do it!Originally posted by Dakota_gsx View Postby budget is whatever itll cost to get the proper parts for this thing. so if getting weisco means there is a chance of them not being enough to handle what im going for, then i will spend more money to get what i need.03 lancer dead
68 gmc w/355 cid rice killer
05 chevy silverado L33
2010 crv Wife's ride
1987 Harley Softail custom
Exactly addict. the last thing i wanna be doing is taking this engine out again next year. no way no thanks eff that.
does anyone know what the wiseco pistons are rated at? i wont be pushing anymore than 700bhp.
And since all these internals have been a mystery, we have been trying to figure them all out.
We are pretty sure the crank is Jun, and we are thinking that the rods are Carrillo because the rod bolts were carrillo. but we will never know.
So the pistons that were in the engine were a 87.5mm piston. all i can find for these engines are 86.5-87.5. since an 87.5 will not fit anymore, we are going with a custom made piston that will be 87.5mm plus about 5thou. dont know the company name, cant remember, but the guy at the engine shop said they make pistons for top fuel and alcohol dragsters. as well as the fastest evo x uses their pistons.
My valve guides are also done along with three valves. i will be picking up some Ferrea valve guides and oversize valves.
When they took apart the head, they said they have never seen valve guides in this shitty of shape out of an rb.
There was also so much oil blow by that there is a rubber/silicone like skin on the exhaust ports of the head that didnt come off in their tank. it will come off with a little scrubbing though.
Exhaust valve and Intake valve. (neither valves were cleaned after they were pulled.)
i havent really heard of anyone running over 87mm. i went with 86.5 just so if i need to i can still bore over one more time and have pistons be readily avaliable since 87mm are pretty easy to get.1991 Nissan Skyline R32 GT-R: 710whp 521 ft/lbs 27.5psi 11.8 @126mph low boost
Lots of guys do. It's the same myth/rare occurance of a failed N1 pump or exploding front diff. You'll be fine. 87.5 is the limit though.Originally posted by DJ View Post87.5mm..i wouldnt want to go over 87mm , the wall are getting a little to thin for comfort after that.No build thread.
1991 nissan
El terror
Exploding front diffs is an issue with high power and hard launches. A genuine n1 pump works good. I wouldn't personally run 87.5 or 88 but its personally not a huge deal. Unless your planning on making a crazy amount of power. Hks, apexi and trust used to make 88mm pistons but discontined them a long time ago.
