Originally posted by ColinR33
View Post
My New R33 GTR - so it begins...
Originally posted by NismoS-tune View PostSweet. Aren't the R33 turbines metal wheel? Should be able to get 1.2 bar out of those. Oh, lose like 60kg and you can keep up to an R3203 lancer dead
68 gmc w/355 cid rice killer
05 chevy silverado L33
2010 crv Wife's ride
1987 Harley Softail custom
Originally posted by NismoS-tune View PostSweet. Aren't the R33 turbines metal wheel? Should be able to get 1.2 bar out of those. Oh, lose like 60kg and you can keep up to an R32-= ECU UPGRADES =- -= LOCKOUT BARS =- -= AERO =- -= SEATS =- -= ACCESSORIES =-
-= PM ME FOR INFO =-
So, got my HICAS lockout bar from Adam @ Feast...
Started the removal....unplug all the wires...
Undo the lock wires holding the rod end boots in place
Pull back the boots and loosen the 4-sided rod end bolts - PITA to get at with the sway bar there...
Remove the bolts holding the HICAS module in place
Unthread the rod ends and remove the HICAS unit!
Now to install the lockout bar....Dammit, won't thread on! What's going on? Ahhh...
The threads are different! Guess it changed from R32 to R33. Time to take it into the shop tomorrow and tap the bar out to match.
To be continued....
Yeah you pull the bulb out too.
The R33 one is in fact different. I would have thought Adam would have known!
Are the mounting points the same? Mine looks quite different.-= ECU UPGRADES =- -= LOCKOUT BARS =- -= AERO =- -= SEATS =- -= ACCESSORIES =-
Well, turns out an R32 lockout bar was shipped to me by accident (yes, Adam was embarassed), I've got the R33 bar know, but I'm too busy to install right now (put everything back together and running HICAS again). If the HICAS light does come on after I install it, I'll just take the bulb out...
Mounting points are about 10mm farther apart on the R33.Last edited by ColinR33; 07-16-2010, 07:05 PM.
