AT LAST - the materials list for the catch can plumbing (all russel parts) :-
6 ft -12 Nylon PROCLASSIC HOSE #632213
3x PROCLASSIC 90° FULL FLOW SWIVEL HOSE ENDS #613193
2X PROCLASSIC 45° FULL FLOW SWIVEL HOSE ENDS #613123
2X -12 AN 3/4" NPT 45° Black Flare to Pipe Adapter #660893
Basic Instructions for plumbing installation of a RIPS oil catch can / washer tank :-
Buy a tank from RIPS
Remove the factory breather fittings from your cam covers (see further back in the thread to learn how NOT to do it)
Machine the holes out and cut 3/4 npt threads.
Install part number #660893 into each cam cover and pint in the direction you want the lines to route.
Make up 2 lines using part number #613193 on one end and part number #613123 on the other end to run from the cam covers to the rips tank
Make up a drain line from a length of hose and part number #613193 and either plumb it back into the oil pan through a turbo drain using a y- adapter OR vent to road or plug
cap off the other fitting on the side of the tank with a russel -12 blank cap ( cant find it on their site )
that just about covers it , if you want pics look back in the thread - the rest is common sence
