Car looks sick!
GTR Wheel Fitment Thread
This is a sticky topic.
'95 Chrysler Voyager options: A/C, power steering, power brakes, cruise control, power windows, power locks, keyless entry, AM/FM Cassette, new tires, automatic transmission, yeah bitches.
Future plans: 18" wheels, performace exhaust, cold air intake, CD player w/ Sub and amp(250watt), black light, big fluffy dice.
Model:BNR32
Wheel Brand/model: Rays TE37
Offset:+22
Tire Size:245/40/18
Tire Brand/model:dunlop direzza dz101 rt615's waiting to go on
Fender/body work:none
Picture:
I cant fit more the 1/2 my finger in the rear fender. in the front its the lowest it can go without super rub, it only rubs when max turning happens
wow how much rear camber are you running? Thats gonna eat tires.Originally posted by danceofcurse View PostModel:BNR32
Offset:+22
Tire Size:245/40/18
Picture:
its even wear on the tires, it may be the angle, the front tire is turned a bit but the camber is killer for sure, on the outsides theres a lil bit of tread left on the insides theres good ole steel showing, i have rt615's to put on though just havnt had the chance im in the middle of a move!
Stagger question
I'm getting some 18x9.5 +20 wheels and I'm trying to decide which tires to fit. I think I'm almost settled on 265/35 all around but I'm considering a stagger with 275/35 in the back and 245/40 in the front. I know different diameters is bad for the transfer case and attessa freaks out, but is there a safe limit? This combination is only about 3.5 mm different is I thought it might be ok.. Any comments on the 265/35 (rubbing in the front?) or the stagger?
Thanks
Doug
Don't stagger a GTR.Originally posted by DougTaylor View PostI'm getting some 18x9.5 +20 wheels and I'm trying to decide which tires to fit. I think I'm almost settled on 265/35 all around but I'm considering a stagger with 275/35 in the back and 245/40 in the front. I know different diameters is bad for the transfer case and attessa freaks out, but is there a safe limit? This combination is only about 3.5 mm different is I thought it might be ok.. Any comments on the 265/35 (rubbing in the front?) or the stagger?
Thanks
Doug1991 Black GTR
BS
If the tire dia. is the same you will have no issues. I will be running 245/45's up front and 275/40's in the back at a height of 25.7".
If the fronts are shorter than the back (ie: 25" front and 25.7" rear) then the ATESSA will just come in a little later than normal.
You won't have the transfer case issues that everyone is afraid of.
When atessa does come in though and your tires are not the same rolling diameter you will be putting a huge strain on your drivetrain.
I'm with Kras, you're an idiot if you stagger a gtr simple because there is zero need to and secondly because you are bound to put more wear on your system.
Originally posted by mcfrank69 View PostModel: SKYLINE GTR R32.4
Wheel Brand/model:GERMANY
Offset: 12 INCH
Tire Size: FRONT TIRE 235/40zr rear 275/40 ZR all streched
Tire Brand/model: falken
Fender/body work:
Picture:
i can show you some picture because a i'm a new
uh 12 inch offset???
I HAVE A QUESTION
SOME LITTLE DUDE ON ANOTHER FORUM TELLING ME THAT
STAGERED WHEELS WOONT BE BAD FOR THE AWD SYSTEM ON THE GTR
I THINK I READ SOMEWHERE IN HERE THAT
STAGERED WHEELS ON GTR AINT GOOD
HES TELLING ME DOSENT MATHER
SOMEONE HELP!
Model: BNR32
Wheel Brand/model: Work, VS-KF
Size: 18x11 Offset +7 tire Dunlop DZ-101 Size 265/35/18
Size: 18x10 Offset +7 tire Dunlop DZ-101 Size 255/35/18
Wheels spacer 15mm
Fender/body to do
