well, it if the thermostat is on the return side from the cooler than it could still be there
because, after starting it, 4-5 seconds later when pressure built in the oil lines going to the oil cooler, oil spewed out of the little holes on the fittings, because i forgot to tight them,
it the thermostat was on the little coming out from the block to the oil cooler, then there wouldn't have been any oil in those lines till the thermostat opened
so i'm guessing my thermostat might still be in there and working
