  • why are you going with gts rear valances?
    GTRC-OG
    • because i think the rear isn't balanced, too much body in front, not enough behind it
      • I have the A6 on the mirrors too.
        For the corner lights the screw in the plastic does help to hold the light but the main piece that holds the light is a metal ball thats pushed into a clip.
        What brand are those FUCA?
        • KTS, worth 400$+ brand new, these were brand new but i paid far far less than 400
          with NSK bearings, we use alot of these bearings in our engineering projects, there are the best
          • Ahhh Frank i always look forward to your updates! Great work again keep it coming!
            1992 BNR32 Skyline GT-R
            Originally posted by bignate
            If you are too lazy to search the site for info you are certainly too lazy maintain a 15+yr old JDM car.
            Ass, grass or cash Nobody Rides for free!!
            • bro this is one sick build thread! keep the updates comin!! haha
              1990 Mazda Manyata (Turbo Miata 6psi 175whp 172wtq)
              1991 Nissan Skyline GTR (13.5psi estimate of 320whp)
              • Originally posted by frankiman View Post
                Ohhhh ok, I thought you were removing n1 stuff and putting on type m.
                Also, looks like you dint always have those n1 ducts, those holes in your rebar aren't factory!
                GTRC-OG
                • yeah i checked i out today, and the bumper was custom cut alright
                  • thats not a bad thing... MOST are like that... only legit N1's had the real precut factory rebar.... mine is pre-cut too, so was my last GTR and so is probably everyone else
                    • thinking about coming tonight? i got something you might want to propose to you
                      • coming where to pick up the parts?... i can't this week man, no $$.... story of my life eh? ill let u know as soon as i can come and get them!
                        whats your proposition?
                        • i got leftover spacers for the front roll center adjuster, i thought that using the extra spacers was overkill
                          • Chapter 14 - Theworkinprogress, week2, part1
                            Day 4 and ~5
                            so i started by removing the snapped bolts from the fronts knuckle
                            step 1, take a bite out of a home made cookie, for motivation
                            step 2, punch the center of the bolt
                            step 3, using a small drill bit, drill as deap as possible in the center of the bolt
                            step 4, using a magnet to clean the shavings is pretty helpfull in keeping your work bench clean
                            then use bigger and bigger drill bits till your hole is about 1/2 the diameter of the bolt
                            step 5, choose the largest extractor that fits into the whole, then gently punch it in
                            step 6, using the right spanner, or vise-grips as i did, then turn counter-clockwise, the extractor will dig into the bolt and it will un-screw out
                            results, bolt #1
                            bolt #2
                            bolt #3 on 2nd knuckle is simply rinse-repeat
                            end with another bite of cookie to celebrate a job well done
                            then got brand new bolts to replace the snapped ones
                            new parts, Moonface front roll center adjuster
                            japanese-only instructions
                            then, screw the nut onto the outter ball joint studs, flat to the end of the stud, then punch it out with a heavy metal mechanic's style hammer
                            punch the other out
                            new vs old hardware,
                            then after a scientific comparison, i found out those studs are exactly the same as the wheel studs, and are in perfect condition
                            how it looks on,
                            didn't use the extra spacer, since my car won't be hella-flush low-as-fawk style, so it would have been overkill
                            knuckles now hyper clean
                            then took out the new Cusco ajustable tension rods
                            then my Cusco ajustable tension rod pipe
                            japan-only use, LOLz
                            and my KTS adjustable front upper control arms, with NSK japanese bearings
                            and my new Whiteline ajustable front sway bar
                            this sway bar is the same size as the stock one, but much heavier, because the OEM bar is hollow and the WL bar is full, so much stiffer AND adjustable ends
                            Moonface use fawking stupid sockets screws that are inaccessible when the front half shaft are fitted into the hubs,
                            so you have to bolt them without the FUCA attached so you can pull the half-shaft out
                            and the Cusco tension rods were pretty hard to fit into the subframe brackets, i had to tap them in with a rubber mallet
                            anyway, everything fitted
                            and the tension rod pipe is hella tight to fit, i tried to shorten it with the adjustment, but couldn't go all the way, so i took i apart to find some of the threads had a little bit rust inside, greased it all and put it back together and worked fine, then i had to spend 15 munites tighteninig the adjustment part with a wescott wrench, since i didn't have the odd sized wrench for it (21mm i think)
                            weirdly, i have to slightly drill out the forward holes on both side of the swaybar for the endlinks to go through
                            day ~5 and 6
                            after i found a very small paint chip on my front passenger fender, i went mad, then taped 1/2'' of foam on it to protect it, since its so close to my work bench
                            then, i did another Seafoam treatment, since i didn't do it the exact right way the first time
                            [YOUTUBE]<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/L0ThVPSE0To&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/L0ThVPSE0To&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>[/YOUTUBE]
                            then i went to my dad;
                            me; ''would you like to participate to my ''save the hammers'' foundation?''
                            dad; ''wtf is that?''
                            me; ''its a group buy on tie rod puller, so i can stop hammer the fawk out of them''
                            dad; ''how is it a group buy?''
                            me; ''well as a group, you give me money and i go to the store to buy the tools''
                            dad; ''.......sure''
                            its pretty much the only tools we didn't have
                            started working on the rear suspension
                            first, took off my Cusco rear strut tower bar
                            no-mo' handbrake
                            then everything off on driver side
                            super dirty wheel bearings, crusted grease
                            then, i remembered Josh's build, where he cleaned alot of stuff around the fuel filler neck, so i did the same
                            holy shiit!
                            i took most of the stuff off with a brush, alot of stuff
                            day 7
                            while listening the to Habs VS Penguins game#4, i got into taking the whole exhaust system out, by myself, with very little room under the car
                            i took me all evening almost
                            started by removing the dump-pipe to down-pipe nuts, with a super long exention and a u-joint, it was a real PITA, mostly because the car was only 18inches off the ground and well... i'm built like a football player, i couldn't sit on my side, so i had to work with only 1 hand
                            then i loosen all the hangars and kept the exhaust in place with a jack
                            then i snapped a bolt (yeah again) joining the downpipe to the cat, because i couldn't get the cat's hanger/bracket out of where it was, so i couldn't take the downpipe out on its own anymore
                            so i slowly descended the cat-back with the jack and suddently the downpipe just fell out
                            then opened the garage door and slid the cat-back outside
                            pure win @ 11pm
                            empty space
                            and capped of the day by removing the rear sway bar
                            at the end of day 7, bunch of stuff
                            • Chapter 14 - Theworkinprogress, week2, part2
                              day 8
                              spent most of day 8 dropping off stuff at shops;
                              on day 7 i went to Autoworx with a friend to drop off his Z32 for an inspection, dropped off my test pipe to have a wideband sensor bung welded
                              then picked it up the next morning, and test-fitted my new wideband sensor
                              Turboquip, i spent over an hour to design my new custom brake lines with their catalog, and they fawking don't have 90deg m10x1 fittings, so i had to go with a bunch of adapters and stuff... anyway, will be covered next week (as i am picking them up tomorrow, from the time i'm writing this)
                              Selex Suspension, where i dropped off my HKS coilovers for a reconditionning and dyno test
                              picked up some more new grade8 bolts washers and nuts at Quebec Bolt industries
                              then went back to work on the car for a bit
                              got my new Whiteline adjustable rear sway bar, and my god thats alot of hardware, as the kit comes with its own endlinks
                              greased up the bushings with the provided grease pack, and bolted it in place
                              and found it came very very close to the rear diff's yoke
                              then i removed the catalyser from the exhaust, to find it had an interesting color insisde, on the intake side
                              then tried to cut the snapped bolt to get it off the cat
                              started with a metal hand saw, didn't quite work
                              then put it in a vice, to try to un-screw just the nut, ended up stripping the nut as it was jammed hard
                              fawk that, power tools, i took out my air powered disc cutter
                              don't forget to wear eye protection kids
                              there we go... results
                              win
                              so thats that... end of week 2
                              alot of work was done, still much more to go, i got 6 weeks left to finish this build and get the car tuned
                              • Frank i wish you lived in Ontario man! hahah so feel free to move to TO would love to be there during all of this epicness!!! keep it commin!
