P/S Reservoir Relocate Part 2
Thanks! I will take a video of her breathing hopefully with soemthing better than a crappy phone cam. She hasn't breathed properly for 2 years now!
Continuing on to something I left a while back, the power steering reservoir relocate to the rad support. I had already cut off most of the stock bracket that holds the reservoir to the strut tower.
I joined the rad support to the reservoir with some shoddy looking welds
But it fit well at least.
I then had the reservoir blasted over the holidays..so much P/S fluid kept coming out, the guy had to bake out the remaining fluid.
I decided that my welds didnt pass QC, so I hastily covered it up with some epoxy putty.
The cap had lost its brass-looking coating so it looked like the rest of the reservoir. Rather than painting it, I opted to polish it.
I worked my way up from 100 grit to 1500 grit sandpaper in stages.
I then applied the rubbing compound prior to polishing.
After two step polishing compound for steel and Fluidfilm..obviously it can look a lot better with more time but I didn't want to spend so much time and have it start surface rusting right away..I will employ the time honored wait and see approach before spending more time on it.
I washed the reservoir and cleaned it thoroughly inside and out in preparation for painting. I painted the reservoir with VHT black caliper paint, and later baked it in the oven for curing.
And the final product..
Originally posted by nimblestix
View Post
