Wheel fitment thread.
This is a sticky topic.
  • he's into euro now. it still sits the same way with the new owner.
    • Thanks for the pics! That's about the amount of stretch i'm looking for.
      I'll run 235/40 up front and 245/40 in the back. If I have to i'll just do the fender work. I'd rather not sacrifice grip by going smaller.
      • 17x10.5 +2 front and rear
        205/50/17 front and rear
        stock fenders with a little pull in the rear
        HeatBloom
        Street Style Since 2004
        www.facebook.com/HeatBloom
        • God help you if you hit a pot hole. How many attempts did it take to get those beads to seat?
          • I need some help guys. :/
            Will 17x8 +35 with 225/45 all around fit on an R32 GTS-T?
            Picked up some rims with tires, planning on changing rubber size soon though.
            • Originally posted by Indie View Post
              yep you will have no problem with those
              • 17'' Work VSXX Gold
                fronts-17x10.75 +4 225/35/17 Yokohama S-Drive / 30mm front overs
                rears- 17x11.75 +9 245/40/17 Yokohama S-Drive / decent pull
                • Completely clueless as to wheel fitment but would anyone be able to tell me how a 18x8" rim with 35mm offset would fit on a gts sedan? I don't have rubber for them at the moment or I would just test fit them.
                  Originally posted by Robski
                  • Originally posted by krystalized_jdm View Post
                    8s would be slightly inside if not flush with the fenders.
                    • Hey guys, quick question.
                      Right now i have 17x8 +38 w/~5mm spacer in front and 17x9 +42 in the rear. The rear fenders are already rolled and I have a set of HSD coilovers that are running about a 1" drop. Its pretty tame and i want something more agressive
                      After seeing Rush's car, i really want some MB Battles but im not sure whether to go for the 17x9 +30 or 17x9.5 +15. Also thinking maybe 17x9 +30 in front and 17x9.5 +15 in the rear.
                      the 9.5 +15 option will stick out an extra 27mm in the rear and 18mm in the front which doesnt sound too bad for the rear but not sure of the front will rub
                      I have a sedan so I would rather not have to pull the fenders and overfenders are kinda out of the question.
                      What's your opinion on this?
                      Edit: would prefer to avoid negative camber
                      This is how it looks pre-coilover, its about an inch lower now but I dont have pics as i lost my phone
                      If you need a clutch safety switch or daytime running lights to pass inspection, pm me and I can tell you how to do it for free
                      1991 Skyline GTS-t 4 Door
                      • This is how she sits now. As you can see there is a bit of room to poke out more
                        • depending on the tire you run the front wont have rubbing issue. i am running a 215/45 in the front and have rubbing issue on big bumps only on the fender liner. if you're only doing a inch lower you will be fine.
                          • Thanks, i have a 215/40 on the front now but its only 8" so we shall see how that goes. I will probably have to wait till fall to order though, gotta save up and pay off other things
                            edit: also, how pulled are your fenders? mine are rolled but not pulled
                            • HeatBloom
                              • That is nuts
